I'm looking to do some lightweight towing (hauling parts to/from my storage container in a lightweight trailer for a vehicle restoration) with my '97 850 sedan (NA base model). It's at about 220k miles, but still running well and I'll change the transmission fluid again, but I'm looking for an appropriate trailer hitch for it.
I couldn't find any info on whether Volvo/Thule made an original for this model and, if so, what the part numbers might be. The prices on the Curt 12211 are pretty good, it seems easy to install, and the ratings seem to match most of the others. Is it a decent one? Are there others that more similar to an OE design (if there was one)?
What do you do for wiring?
1997 850 sedan trailer hitch
- Has thanked: 1851 times
- Been thanked: 1712 times
Good luck with the OEM part. I looked it up on VIDA and it is a real mess of part number up-ticks.
There were also 2 different sizes of tow hitch. 2" and 1 7/8" to complicate things.
If I read it correctly, you may still be able to order a new one for $360-400 US.
Confirm part # is correct with dealer. Part # 9134150 (replaced # 9134257)
- Has thanked: 1506 times
- Been thanked: 3819 times
You can go to Uhaul and a hitch put on and wired pretty cheap
For a Class 1 small trailer, don't sweat the rating
I have the OEM class 3 on my 1999 which integrates nicely into the body but the install was big.
Thanks for the suggestions and the lead on the OE part #s.
The last time I had priced out Uhaul, they were significantly more expensive, but it looks like--excluding installation--it's on par for the Curt hitch. I'll see what the installation cost is and how they do their wiring.
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
The draw-tite hitch installs with 3 bolts - but you do have to undo the bumper bracket to sneak it in-if your bracket is really rusty you can force it into place best to just look for a used one and do the wiring yourself I don't trust most places as they wire with those crimpy thingies
The Draw-Tite 36262 looks identical to the Curt, so that's reassuring (Edit: and the Draw-Tite is the model Uhaul sells for the 850). I had seen other photos that looked closer to the OE (now that I've looked it up with the part #s).
How do you suggest doing the wiring as I want to avoid the crimp things? Where do you tap into the wiring harness, at the tail lights?
I found this other thread which has some tips on the wiring. I assume any wiring module (Uhaul, Curt, etc.) would probably be fine as long as I splice instead of using the clamp-on connections, correct?
combatkarl
- Year and Model: 1997 850 GLT
I am a terrible at using a soldering ironmorgant wrote:How do you suggest doing the wiring as I want to avoid the crimp things? Where do you tap into the wiring harness, at the tail lights?
Use MVS Amazon link to buy them? NAPA auto stores used to carry them, but I've yet to find Posi Locks in any store.
Also, etrailer is a good source for hitches. I've used them in the past. Most vehicles installation is fairly easy. https://www.etrailer.com/hitch-1997_Vol ... Series.htm
- 955 Views
Last post by ashitaka695
- 2846 Views
Last post by matthew1
