Hi all,
I'm a longtime Volvo admirer and relatively new owner of a used '98 V70 base model. Recently, I had some CEL blinking while driving to get my inspection done, turned around and got my scanner out. I was hoping for some insight.
After seeing a misfire code (P0304) in cylinder 4, I pulled out all the spark plugs (Volvo OEM via FCP Euro, replaced about two months ago) and saw some dark-colored residue.
On spark plug No. 3 (and No. 2, too, I think) there was also a light-colored, ashy residue visible on it.
They look almost as dirty as the 2-year-old Denso plugs I pulled out of the car just two months ago. I recently also added STP Fuel Injector Cleaner), running 91 octane and then 89 octane in my last two fill-ups.
My question is: Is this level of soot normal?
Should I try a higher-quality fuel cleaner, like Lucas Oil? Use 93 octane?
1998 V70 Spark plugs look dirty, but are they normal?
Spark Plug Wars - What's Best for Your Volvo
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
I don't think I've seen plugs that dirty before... and certainly not after 2 months. Not normal.
I'm not sure about your model, but it's pretty clear that the 850s and early V70 do NOT enjoy the multi-electrode sparkplugs. You should probably try a properly gapped single electrode set, and make sure that the rest of the ignition parts are up to Stage 0-reqs.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
jcdillin
- Year and Model: 06 V70R
- Been thanked: 3 times
Ehh, I think you may have been sent the wrong thing if you ordered real volvo plugs.
https://www.fcpeuro.com/products/volvo- ... 90-8692071
I only use those or bosch copper electrode and properly gapped.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Say it ain't so, FCP!
Retired:
2015 Volvo S60, T5, 85K
brunocerous
I see the difference! But that FCP link tells me, "This part does not fit your 1998 Volvo V70 Base."
- Been thanked: 504 times
Stay away from Denso plugs, they are known to break the tip off (Search Volvospeed).
- Switch to NGK Iridium BKR6EIX and you will never look back.
- Although Iridium plug is $7/each (Advance Auto Parts), Iridium easily lasts some 100K. The car will run very smoothly, you may see better fuel mileage.
brunocerous
Thank you. I might have to swing by the auto parts store to get replacements.Sommerfeldt wrote:I don't think I've seen plugs that dirty before... and certainly not after 2 months. Not normal.
- S
brunocerous
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Do a compression test +- leakdown when you change the plugs (again!). You seem to have a couple of wet plugs, from running rich, incomplete combustion or from oil, though looks a bit more like fouling from gas than oil. Do you use any or much oil? My 850t plugs don't last terribly long because I have what I assume are leaky valve guide seals. Great compression, though. So I experiment with various grades of oil to try to keep consumption reasonable, which is working well enough. I'm a convert to 93 octane gas, finally, as well. Learning as I go along...
- 1163 Views
Last post by E Showell
- 1855 Views
Last post by liquidBlack
- 4146 Views
- 1056 Views
Last post by jmscdgn
- 11 Replies
- 933 Views
Last post by vtl
