'99 S 70 P 1017 and running cooling fan after shut off
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
With battery disconnected, did you try remove and reseat on the ECU connector? It's FREE!
Current Volvos:
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
No, but I will. Need the tool first.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Been thanked: 4068 times
I'll ping Matt to see if he wants this for the tool program
- E Showell
I have it on order and might consider donating it to the loaner program once I am done using it.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
I filled the gas tank and the CEL turned itself shortly thereafter. Coincidence?
'95 855 auto (sold)
'95 855 auto (sold)
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Burnt bulb?
Does it appear on bulb check?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- E Showell
Don't know what "bulb check" is.
'95 855 auto (sold)
'95 855 auto (sold)
- FLXC90
He's asking does it test at key pos II prior to start.
Current Volvos:
- E Showell
Yes. It comes on at start up along with all the other lights.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Well -- confirmation of bad ECM this morning. Had local independent read codes with Volvo scanner and got "Series 900D" fault, which I am told is a bad ECM. I had already acquired a used ECM in anticipation of this news and the ECM removal tool, so I guess next step is to pull the module and get the used one cloned.
Interestingly, my cruise control appears not to work after the scan. Could be pure coincidence, but a used stalk solved that problem a few months back. Perhaps the used stalk has finally failed.
'95 855 auto (sold)
'95 855 auto (sold)
- 2785 Views
Last post by OnTrack
- 677 Views
Last post by DGM
- 2695 Views
Last post by cleven
- 2763 Views
Last post by cmbfoto
- 15354 Views
Last post by FREEBUSINESSES
