1995 Volvo 850 T-5R Project cleaning up and refreshing.
854T-5R
Year and Model: 1995
Post by 854T-5R »
Hi, here is mine 850 with 200 000 miles on clock (manual).
Some things what has been done to my Olive.
Also got some mods on it: 16T @22PSI
Blue Injectors,
DP, Decat 3'
RIP kit,
302mm brakes with Feredo DS2500 Pads.
5k ago changed all belts, tenssioner, pump etc.
But has few issues wich i am trying to fix.
Hopw you can help me if needed.
Here is some pics. (Bought car year ago)
854T-5R
Post by 854T-5R »
ATM trying to sort out engine, seals, bearing, etc
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The rod bearings look pretty grim. How does the crankshaft look?
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
Agreeing with Lee on the rod bearings. Might as well mic up the crank journals for roundness while you're that far into it. If there's any scoring on the journals, you'll want to have it turned a few thousandths and install oversized bearing inserts.
Notice that the bearing inserts don't have a little rectangular dimple in one upper corner to set into a mating cutout in the rod casting. If you replace the inserts buy a decent quality of inserts that have that dimple, especially if you plan to juice up the power. That little dimple on each half shell will help to resist spinning a bearing at high rpm.
854T-5R
Post by 854T-5R »
JimBee wrote:Agreeing with Lee on the rod bearings. Might as well mic up the crank journals for roundness while you're that far into it. If there's any scoring on the journals, you'll want to have it turned a few thousandths and install oversized bearing inserts.
Thanks lads, yes i already ordered bearing from volvopartsonline dot com. Will try my best.
854T-5R
Post by 854T-5R »
Ozark Lee wrote:The rod bearings look pretty grim. How does the crankshaft look?
Crankshaft look better, but i thing i should check, and messure it.
JimBee
Post by JimBee »
The crankshaft should be mirror smooth and shiny and, of course, perfectly round :)
A couple of other points that you might find helpful:
- use a tap to clean out the threads in your engine block
- for the end bolts on your oil pan b/c they will have some thread lock or sealant in them that can
prevent proper tightening
- likewise clean out the threads on the firewall side of the head where the coolant pipe flange bolts on.
- to complete that prep for proper torquing of bolts, clean the threads on the bolts.
- using engine degreaser and shop towels or rags, wipe out all the cylinder bores until the rags come clean
then use a ball type hone to rough up the cylinder bore surfaces so the new piston rings will chafe in properly. If you skip that step, the rings won't run in and oil and compression can slip past.
Details!
854T-5R
Post by 854T-5R »
JimBee wrote:The crankshaft should be mirror smooth and shiny and, of course, perfectly round :)
Details!
Wow, thanks for usefull information. Looks like this prject will finish after christmas.. :/
