It froze the other day before I had a chance to put in anti freeze. Since then the back washer fluid doesn't work. Front is fine.
The hole is not blocked, where can I check for the pipes?
This is a v70 2004
V70 back washer fluid stopped working
Are you getting pump action when you push switch? Listen for the pump with the engine off, ignition on.
- 3334 Views
Last post by qwertyjjj
- 2224 Views
Last post by Sixthandredline
- 36 Replies
- 24712 Views
Last post by StickyPocket
- 1174 Views
Last post by lcc014
- 468 Views
Last post by cn90
