This happened the other day after the temperatures got below freezing.
The rear wiper still works.
The front fluid and headlight fluid still works.
As I understand it, this is all from the same pump on the V70 so it cannot be a fuse.
I took the tailgate trim off and pulled off the pipe from the rear connection and then tried the lever but still no fluid comes out.
I cannot see any fluid underneath the car so it doesn;t seem like it's leaking anywhere.
Any ideas of what next to try?
Apparently there is a connection valve inside the rear panelling as per the attached diagram but I cannot seem to pull the trim off.
V70 2004 rear window washer fluid stopped working
qwertyjjj
- Year and Model: V70 2004
I took off the back tube and took a bicycle pump and pumped air through it. I can hear air coming out as bubbles in the front reservoir so there is no blockage. However, when I push the lever for the back, the wiper comes on but still no fluid. No fluid comes out of the pipe even when disconnected.
- 1071 Views
Last post by qwertyjjj
- 10 Replies
- 2329 Views
Last post by StijnC70
- 2221 Views
Last post by Sixthandredline
- 36 Replies
- 24687 Views
Last post by StickyPocket
- 837 Views
Last post by freedomfries
