okay so i have had some rough days trying to get this car running normally. it all started a couple weeks ago i turned car on and it shut off after runnin for about 3 seconds. started up got me to work then when i tried to get home it wouldnt start again. long story short i cleaned MAF, replaced spark plugs, cleaned IAC valve, throttle body control valve, replaced thermostat and gasket and replaced ECT sensor. When trying Ozarks fuel pump relay jump the car runs great. got a new KAE fuel pump relay from autozone and the car shuts right off again. returned the new relay to autozone and am currently using a staple to jump the relay 15 and 87. the relay is definitely not working but a staple is... so does anyone have a solution? should i try the relay from the volvo dealership or should i check the relay harness for wiring issues first? im low on cash so i think the staple going to have to get me by till my next pay check but would LOVE to know how anyone else fixed this issue. thank you so much
thunderhawk
fuel pump relay issue
thunderhawk
- Year and Model: 98 s70 t5
okay nevermind picked up genuine volvo fuel pump relay and cars back to perfect normal. thanks anyways guys and always use genuine volvo parts is what ive learned from this mess!!!!
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
I've got a Volvo fuel pump relay coming in the mail soon... I hope to have a similar experience!
Retired:
2015 Volvo S60, T5, 85K
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Glad you got it fixed andthunderhawk wrote:okay nevermind picked up genuine volvo fuel pump relay and cars back to perfect normal. thanks anyways guys and always use genuine volvo parts is what ive learned from this mess!!!!
Thanks for closing the loop!
That's what MVS is all about.
BTW - https://www.matthewsvolvosite.com/forums ... =1&t=44724
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
Another nail in the aftermarket coffin. I read somewhere that typically something like 1 in 10 aftermarket relays are faulty.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
- greg850r
- Year and Model: a long list
- Been thanked: 26 times
Anyone know if I can drive the car 30 miles on a jumper wire? i bent a nail and got it to run but don't know if the relay would turn the pump on and off while driving.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
30 miles or 50 km is fine
At 32 miles the ECU will eject the warp core and you will have anti=matter strewn all over the highway.
(seriously, you will be fine - pull it out (HOT HOT HOT) when you get to your destination)
- greg850r
So after I took it out and brought it into the house to warm up I plugged it back in and it got me there. Next morning no start again so I put the new one in and it ran. Seems they fail when cold first. I am thinking about replacing the two internal capacitors since I have too many 850 to buy a spare for every glove box. Anyone want to suggest a source? I remember seeing a thread somewhere about using ones rated at a higher voltage than the originals.
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
Its cheaper to get them from a PnP - certainly check. Is the root cause of failure for fuel pump relays actually known to be the caps?
- Been thanked: 504 times
Also,
If you need the car to go to work, then make a jumper with a built-in fuse and jump 15 and 87 as below:
More info below:
https://www.matthewsvolvosite.com/forums ... hp?t=52252
More info below:
- 5076 Views
Last post by wizechatmgr
- 11 Replies
- 2718 Views
- 16158 Views
Last post by Richard99
- 19 Replies
- 9496 Views
- 17 Replies
- 7660 Views
Last post by cn90
