155/70R19
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Any rims available for 240s?
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
That's spare tire size territory.
1988 Volvo 760 Turbo Wagon
93Regina
Post by 93Regina »
lummert wrote:That's spare tire size territory.
My VW bug spare tire (Tire 1) is taller than 185/75/14 tires for 245, but this tire (#2) is taller. Speedometer would be off via 5 mph from VW tires.
I suspect this 19" tire would work, if shocks/etc were fit for duty. Any rims for 245?
93Regina
Post by 93Regina »
I wonder if BMW i3is using 5 x 107.9 pattern?
lummert
Post by lummert »
165/80-15 for a VW Bug is incorrect. It was 155-15, 165-15 was VW Type 3. The correct aspect ratio for a 155-15 is 82. The original 155-15 spare tire in my 88 765 is 25" diameter or 78.5" circumference. I measured it to determine reasonable tire size for the car.
93Regina
Post by 93Regina »
lummert wrote:165/80-15 for a VW Bug
I would have to find an owner's manual, but when scanning this/that, that's what they said.
I've got two spare tire rims mounted with this 165 size, and they work great in winter weather on drive wheels.
93Regina
Post by 93Regina »
In 1956 the stock tire size was 5.60-15
Now, that's bias-ply tire size. Which was equivalent to 155R15 in radial, but you won't find that size. 165/80R15 is about the closest common tire you'll find these days, which is still going to be a tiny bit shorter in diameter.
lummert
Post by lummert »
http://www.tiresize.com does show the modern replacement tire size as 165/80-15 for the classic VW Beetle.
Some useful info:
www.tiresize.com/chart/
93Regina
Post by 93Regina »
lummert wrote:Some useful info
Those Bridgestone's ologic tires designed for BMW i3 and i8 electric cars have a load rating of 1,102 lbs, whereas 185/75-14 tires are rated at 1,290 lbs.
But, Volvo 240s have a bolt pattern of 5 x 108 mm, where BMW's is 5 x 120 mm. It's rather doubtful rim makers will make a rim with Volvo's pattern. There is a rim adapter available, 5 X 108 to 5 X 120 Wheel Adapter, but the other measurements would have to be considered.
I read somewhere some 25-30% more efficient tires...around 7 mpg gain for a 25 mpg redblock.
