99 v70 - moaning when coasting
whatgoeson
Year and Model: 1999 v70
Post by whatgoeson »
hey there, first time poster-
had this issue today with my 99 v70, 150k
there is this moaning i get when driving. goes away when i give her gas/brake..this sound like a bearing issue??
Reason: Clarified title - please, no CAPS or HELP in titles - read the rules
Has thanked: 2199 times
Been thanked: 1852 times
Possibly but we will need more info to try to diagnose from afar!
I assume the noise is only there when you the car is moving and coasting, or is it there all the time and you can only hear it when you are coasting?
Are you 100% sure that it is not there when the car is at rest? This will help identify the likelihood of engine/trans/driveline issues.
If you can record the noise and post that may also help.
whatgoeson
Hey neil, 100% sure its not there when at rest, will try to capture audio later on. Just checked under hood and everything seems a-ok, power steering could use a top off.
Been thanked: 4065 times
You can turn the engine off when coasting to ascertain if its an engine vs driveline issue.
You can slip the trans into neutral to tell if its in the trans
Im guessing driveshaft or wheel bearing. Moaning is more like wheel bearing sound. If it is in the front, then gently swerving back on forth on BQE at 0300 hours might confirm its a front wheel bearing and which side is bad, too.
whatgoeson
great ideas abscate, will try later hopefully- heres video for sound now
whatgoeson
BUMP!
Hmmm- more of a hum than a bearing noise, which is a whir or a drone. The frequency is too high....almost sounds like a truck braking to a stop type noise.
whatgoeson
Absolutely, a few friends have expressed little concern, thoughts are more along the lines of "maybe some panel is rubbing" or "maybe its a belt" - not seeing any signs of either.
Not afraid to bring it into a shop, i just dont have a trusted mechanic in NYC yet(bought this car 3 weeks ago and havent owned a car in the 9 years ive lived in new york) - i just dont wanna get the run around
