Will these Radio Shack bulbs work in 850 dash?
- Has thanked: 312 times
- Been thanked: 818 times
I will guess you are talking about the bulbs in the cluster, where there are usually 194 bulbs? A 194 is 3.8 watts / 14 V, I don't think I would be dropping 20 W bulbs in there. Might catch it on fire.
Teddy1975
- Year and Model: 2007 V50
- Been thanked: 7 times
More likely burn a fuse...
You need something like these: https://www.amazon.com/SYLVANIA-Long-Lif ... 00318V1BU/
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
I was kidding
A 1.4 W bulb (#74) in there will be dim. Standard replacement is the 14V/3.8W (#194) although it is not the 12V/3W that shipped with the car; if you want a treatise on bulbs check this out:
https://www.matthewsvolvosite.com/forums ... =1&t=61483
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Pointers appreciated. Searching around some more I found cn90's nice tutorial that includes illustrated instructions for removing the cluster and bulb types showing where the two different types go. On the same page, helpful info from others on where to buy...
https://www.matthewsvolvosite.com/forums ... 44#p143724
- 5232 Views
Last post by AVOIT17
- 45 Replies
- 23183 Views
Last post by esl_97_850_T5
- 616 Views
Last post by oragex
- 1242 Views
Last post by regent
- 654 Views
Last post by EngineeringBloke
