1996 850 20V Timing Belt Kit and Water Pump
beigg
Year and Model: 850 97
Re: 1996 850 20V Timing Belt Kit and Water Pump
Post by beigg »
PeteB wrote:We have a Harbor Freight nearby and they have torx bits that are just bits
and probably take 1/4" drive or 10 mm, that I could use an open end wrench
on or vice grips - not sure if that is a good idea. Or I could cut down the back
end of it to make it low profile then put it in a socket.
Any suggestions?
Those worked just fine for me.
ugh smh 850 Turbo fridge
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
Any tips on how to get around the pin?
I'm going back out to take another look.
beigg
Post by beigg »
PeteB wrote:Thanks erikv
OK, got all the old parts out and I see that there is a plastic pin as part of the
lower plastic housing that is blocking the belt from coming off. Is that there
just to make it difficult to do this job or was I supposed to take the lower
plastic housing off? I didn't notice that step in either video.
It seems like it is impossible to get the old belt off or the new one on.
I read somewhere that some people take the harmonic balancer off, but I don't
want to risk turning the crank with the belt off. I take it that the large 30mm
bolt has to come off or is it just the four 10 mm screws?
2 10mm unique pin bolts. remove those and it'll be smooth sailing.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
If you want to remove the harmonic balancet you also need to remove the 30mm bolt; there's no getting around this.
The nub you see on the oil pump can be dealt with without removing the balancer.
PeteB
Post by PeteB »
OK, I looked closer and the nub is metal with some sort of rubber on it. Also
noticed that the nub is harder to get around taking the belt off, so I cut it as
Robert suggests. New belt took just a few minutes to work in there, it is in
at least on the crank shaft.
Got all the water pump bolts off and now it is stuck, tried prying a bit, tapping
it lightly, does not want to budge - suggestions? The belt was only done once at
70K miles so I doubt that the water pump was ever replaced.
beigg
Post by beigg »
Were all 7 bolts removed?
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I just changed the water pump on my '97 855 GLT at 186k miles a month ago. It too was on the original water pump. To get the old pump off the engine block I had to strike it gently on the pulley with a small deadblow hammer. If I'm remembering correctly, one or two taps was all I needed to break the seal at the gasket. The old gasket was half adhered to the water pump and half to the engine block.
The harder part was gently removing all the traces of the old gasket with a scraper from the engine before I could install the new (Aisin) pump.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Cut the belt off, always goes on pretty easy.
Tap the water pump pulley and it will pop loose.
Has thanked: 292 times
Been thanked: 765 times
I agree with Robert - the other posts are good advice. :)
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
bugs11
Year and Model: 850 1996
Post by bugs11 »
Try a dab of white out on the crank pulley valley to get the tiny notch to appear. I was in the same boat, for the life of me I could not see the notch on the crank pulley until I put a dab of white out on it. And I also cut my timing belt belt off - as Robert suggests.
