So the last vid indicates spark, hooked up coil lead and sure enough, now it fires up..?!!
What could possibly lead it to need 2 minutes of cranking before spark comes along?
97` 850 R manual swap, long crank intermittent spark/start Topic is solved
- Been thanked: 4069 times
Let's try that spark check with a plug attached and grounded with a wire and see if it's still erratic
FIXED!!!
Drumroll....
It was the crank sensor polarity.
Auto flexplate with square trigger holes as the newer flywheels. Install an old flywheel with round trigger holes and you`ll want to reverse sensor polarity.
However, it will fire with wrong polarity, crank time is looonger and your timing will be off.
M4.3
Drumroll....
M4.3
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
gswede wrote: - Short "fan" belt as the AC had been inoperable since 2002, many receipts from PO attempting fixing it. Figured no need for a belt spinning non working equipment.
Do you know what brand/ part number the short belt is? This would be useful to know, several people were looking for a short belt to bypass the a/c compressor.
Nicely done!!
De nada
If you do this, crimp and solder the wires for trouble free DD
And for the love of GOD, keep the auto ECU, the revhang in the manual ECU sux.
Cannot even begin to describe how much better auto ECU driveability is on a manual swapped car than one high mileage 850 original manual with rev hang.
Total control of torque and revs with pedal beats ECU interference, especially during gear change..
- henrysin44
- Year and Model: 1994 Volvo 855 Turbo
- Has thanked: 2 times
- Been thanked: 3 times
I manual swapped my 850 2 years ago and ever sense my volvo would crank for soooo long, sometimes a scary long time (not very fun to experience on road trips). This post is a life saver, i had no idea about the different flywheels, now it fires up within a second!gswede wrote: 23 Mar 2016, 16:54 FIXED!!!
Drumroll....
M4.3
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
I'm in the middle of my manual swap on the '97 T5 and wonder if this is going to be an issue.
My car is no longer an M4.3 (Swapped M4.4 a while back) and it's going COP in the process.
I know the M4.4 started quicker, due to the system remembering where is was and not having to find #1 first (like the M4.3), which resulted in shorter start times.
I suppose it won't hurt to swap polarity, regardless.
- 1130 Views
Last post by nmotzing
- 18 Replies
- 1680 Views
Last post by erikv11
- 817 Views
- 5678 Views
Last post by Volvoblackdog
- 389 Views
Last post by JimBee
