Thanks for your detailed response.
I drain & filled my ATF last week and the car has been driving great.
In comparing old fluid with new, it was extremely dark. I think it was definitely overdue.
I will be performing these drain & fills every 30k as suggested.
04 s80 - specialist says don't touch ATF, but why?
oldironsights
- Year and Model: 2001 S80
Very good, but you still need to drop the pan, clean the pan & replace the filter.
Drive ability will improve even more.
volvobro
- Year and Model: 2004 S80 2.5T AWD
I'm not entirely sure if my car has a transmission filter as I have been unable to find any information related to it.
2004 S80 2.5T AWD - First car, first Volvo.
Follow my progress to stage 1 here.
Elliot9874
What was the result ?
BobbyS1
- Year and Model: 2000 V70 Estate
Just changed mine it was minging!
Can someone tell me where the ATF filter is?
I have 1999/2000 V70 estate right-hand drive tried to order filter but shops in UK don't seem to stock them is it a dealer trip?
Regards
Bobby S A Yank in England
Regards
- June
- Has thanked: 523 times
- Been thanked: 261 times
Only the 2.9/T6 equipped with the Hydramatic 4T65 E has a filter. Your 5 cylinder Aisin transmission has a screen in place of a filter. JuneBobbyS1 wrote: 18 Nov 2019, 13:52 Just changed mine it was minging!
Regards
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
rb61
- Year and Model: 2001 s80
At one time (many decades ago) I heard a theory that a high milage transmission could start to slip if the old fluid with metal/grit was replaced. Some people felt that the debris was what created necessary grip between clutches. Your mechanic may be a believer.
The new found wisdom on these is the following; of changing your fluid kills your transmission, it was on the near death list anyway,
There is no question that regular renewal of ATF prolongs life of the transmission.
CorpsOfficer
- Year and Model: 2006 S80
- Been thanked: 4 times
For those who are curious, I completely changed my transmission (an Aisin 55-50SN) oil for the first time at ~135,000 miles and sent out the oil to a laboratory for analysis. This was the report from the tests:
I do not yet have a comparable analysis for a clean oil or lightly used oil sample but this was more than enough to convince me to change the oil more frequently. I'm at 20k miles on flushed oil (I pumped all the oil out using the radiator drain when I sampled for this report) and it still looks red, smells new, but is beginning to mark a paper towel lightly brown. 30k miles is a good interval for a transmission of unknown history. If the oil was changed at regular intervals since factory, 50k-60k miles seems adequate to me. Volvo I believe recommends a 52,500 mile interval for "towing" applications in the maintenance schedule. Do whatever you are comfortable with, but I would not listen to those who tell you to never change the fluid.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I purchased a 98 S70 T5 with 230ish K in 2012. The transmission fluid was coffee with a tint of silver. I used the same method and flushed it and drove it for a year. Flushed the following year as it started to get dark again. Car did not have problems but felt slower. Glide again after the second flush. I've only drain and filled once or twice out of caution for Honda's but last year I flushed, bypass the radiator and installed a transmission cooler on a 220K 03 Odyssey and have not had a problem. Had the van since 154K and it's the smoothest thus far with the cooler trans_fluid.CorpsOfficer wrote: 01 Jan 2020, 15:26 For those who are curious, I completely changed my transmission (an Aisin 55-50SN) oil for the first time at ~135,000 miles and sent out the oil to a laboratory for analysis. This was the report from the tests:
Seeing your report I think I will stick to flushes rather than putting clean fluid into dirty. Diluting to eventually to have cleaner fluid I suppose gives some a peace of mind but I haven't experienced or know of a case where a flush did a transmission in.
