etm Wiring
nthnnxn
Year and Model: 2000 S70
etm Wiring
Post by nthnnxn »
02 v70 turbo...Doing an engine overhaul and during tear down process broke the ETM connector. Got connector replaced from dealership... I coulda sworn I swapped out the right wire in the right slot in the rebuild process... But at any rate when I start the car its a very rough Idle and I have no power, as in zero...not even limp mode.
Any diagram of that connector showing the wire color and position would be greatly appreciated, as well as any other ideas for my, "zero power" capabilities.
Thanks
Nathan
packetfire
Year and Model: 2010 v50 2.4i
Has thanked: 17 times
Been thanked: 30 times
Post by packetfire »
Here ya go...
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
jimmy57
Been thanked: 320 times
Post by jimmy57 »
He has a 2002 with an ETA, not the ETM.
packetfire
Sorry, I could have sworn that he specifically requested the ETM connections and connector layout. :)
But as Jimmy merely criticized, and did not attempt to provide the ETA diagrams, here they are:
jimmy57
Post by jimmy57 »
Sorry if it you decided it was critical. It was not intended that way.
I guess I should not have commented.
nthnnxn
Post by nthnnxn »
Thanks for all that guys!! I did it right the first time. However upon starting the engine, its a rough idle... Also the Accelerator is responsive, so no more "zero power" issue! Any ideas for possibilities of rough idle, other than the timing being off?
Has thanked: 1505 times
Been thanked: 3818 times
Plugs, coils, compression....and the ubiquitous vacuum leak of course.
nthnnxn
Post by nthnnxn »
Thank you very much Abscate!! I hope its somethin simple like you are suggesting and I dont have to tear it down again...Cant wait to be done this rebuild!!
nthnnxn
Post by nthnnxn »
Turned out that 2 plug coils were swapped. And Now The car is running AWESOME!! However I am wondering if the top motor mount/crossbar being mounted (vs. Not being mounted) had anything to do with a rough idle upon engine start (When crossbar was not mounted)?
