1998 Volvo pcv question
JasonVolvoMan
Year and Model: xc70 1998
Post by JasonVolvoMan »
Just finished with replacing my pcv system on my 1998 xc70 with 205000 miles.
After installation was complete I started the car up and stood over the engine to make sure everything was good. The first minute everything seemed fine. Then I noticed the coolent overflow bottle start filling with a brown liquid and eventually over flowed with Murkey brown, oily coolent. I have. Ever seen this happen before. So I drained the coolent system. At first nice green coolent came out then brown coolent and the. What looked to be straight coming from the drain stem of the radiator.
Next I pulled the oil pan plug out and out. Some basically chocolate milk straight coolent, not even oil.
Would this be a bad turbo or a blown head gasket. ?
1998 xc70 170,000miles
1983 240 turbo one owner and 120,000 miles
Previous cars
1983 240dl 235,000 miles 5 speed. Should of never sold!!
1990.240dl 280,000 miles 5 speed. Should of never sold!!
2004 xc90 60,000 miles 3rd tranny
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Hey Jason, sorry to read this. How was the car before you tackled the PCV system? As far as I know, it's not really connected to the coolant in any way...
Retired:
2015 Volvo S60, T5, 85K
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
I don't this this would have to do with the turbo. Not sure this has to do with the PCV, either. The only thing I know relating to brown/oily coolant is a bad head gasket.
JasonVolvoMan
Thanks guys. I think what happen is when I did the pcv the engine finally got a strong vaccume on it and blow away a seal that was already bad and made it worse. So now there is a vacuum straight to the oil.
Previous cars
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Either the head gasket is bad or the oil cooler in the radiator has cracked and your mixing coolant with oil in there.
JasonVolvoMan
Thought of the radiator. Out I replaced it 2 years ago. Going to try to do a cooling system pressure check. And should I hope pin point the problem
Previous cars
bmdubya1198
Very well possible the improved vacuum finally blew out the seal. A compression test will reveal a leaking head gasket. Definitely check the radiator, too, considering the oil cooler is part of it.
polskamafia mjl
I'm confused what kind of seal you guys think is damaged by vacuum but not excess pressure from a clogged PCV?
JasonVolvoMan
I forgot to say I had low coolant light came on with no visualable leaks anywhere
Previous cars
bmdubya1198
polskamafia mjl wrote:I'm confused what kind of seal you guys think is damaged by vacuum but not excess pressure from a clogged PCV?
The PCV being clogged is probably what weakened it to begin with. Shock to the system..? Or just bad luck that it happened when it did.
