yet another PCV question
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
I guess about 4 years ago, a shop I trust did a PCV job on my 1994 850T / automatic Volvo. That said, I am losing oil out of an admittedly weak rear main seal. So I did the surgical glove on the oil filler cap test, and found this: Cold car, ambient around 76degrees F. With the glove in place and the first start of the day, the glove inflated and stayed there at idle. I ran the RPMs up to about 2K and the glove stayed inflated for about three seconds, then it deflated. When i let the RPMs return to idle, the glove stayed deflated and it got slightly sucked into the engine. Rising the RPMs again inflated the glove again, but then it deflated again..
What gives? Do I need to do another PCV job on the car? Is something else going out?
Thanks in advance.....
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Start by making sure the PTC is open. From there, if the PTC is good, then I would pull the elbow from the oil trap to the block and check the passage from the sump up to that elbow.
azureblue
Post by azureblue »
Thanks - Is it better to clean or replace the PTC valve? There is a junkyard close by....
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Cleaning should be sufficient but you can always grab a spare one if you like. Just make sure you clean the spare if you decide to use it.
azureblue
Post by azureblue »
Of Course. I usually go to the parts yard and practice a take apart - easy to get a spare. Thanks.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Has thanked: 1611 times
Been thanked: 4073 times
Its not even a valve, its just a hole. The PTC connector is just a heater connector to help it clean, but there is no mechanical actuator there at all.
The last time someone replaced a hole was in the movie 'Yellow Submarine"
azureblue
Post by azureblue »
Just making sure I did the job right - after cleaning the valve I blew through it both ways at ambient temperature and got a little resistance, which I expected. Car seems to come on boost a little smoother. I'll do the glove test today to see if the Crankcase pressure issue changed. Thanks for the help - much appreciated.
Now thinking about putting in a catch can, since I see how easy it is to get to the plumbing.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
The glove test should only be done on a warm engine.
azureblue
Post by azureblue »
It was originally run on a warm engine. And I'll do the next glove test, when the car is warm.
BTW the PTC valve was clogged when I first took it off the car to test it..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
