I am replacing a front hub on the '94 850 black Wagon I had bought last summer.
I Need to pick up the E-torx socket for the hub bolts tomorrow.
Can someone tell me what size it is so I do not have to buy a set?
Thanks.
Hub E-Torx Bolt size.
Ben850
- Been thanked: 7 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Ben850
Thanks.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
A full set from E6 to E16 cost less than $10 and there are several locations that use them. My guess is that you will pay as much for 1.
Ben850
On my way to Harbor Freight now.
- Been thanked: 4068 times
I've got spare bolts if needed.
Ben850
Thanks Steve. I think the new one comes with them, but I'll keep that in mind.
This is the '94 N/A Wagon I've had in storage until last week.
It needs a little cleaning up, but the drivers front hub bearing was the only thing keeping it off the road.
Oh, the wheel speed sensor ring was taken off completely so I have a new axle as well.
The hub bolts turned out to be E-16.
No matter, I had to get a salvage knuckle. The original bearing is welded inside.
- IMG_5232.JPG (194.27 KiB) Viewed 2671 times
My left Hub tapped out with light hammer. The right needed a hydraulic press.
Looking good !
Looking good !
- 1924 Views
- 12 Replies
- 3754 Views
Last post by JimBee
- 2412 Views
Last post by [email protected]
- 1900 Views
Last post by Mikaro07
- 1896 Views
