Slack Seat Belt on 89 760 Turbo Wagon
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
This topic is in the MVS Volvo Repair Database » How to Read An Engine In A Marketplace/Craigslist Ad
JohnR
Year and Model: 2001 Volvo XC
Post by JohnR »
I was wondering if there is a 'trick' to adding tension to the seatbelt winder - it is not retracting the seatbelts all the way.
Or is it a case of getting a better one at the used parts place?
Thanks for any help
John
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I don't know of any trick to do this. Most seat belts suffer from this problem after some years and depending on how many times they have been pulled out an let back in.
The only thing I would suggest checking is that the reel at the bottom of the belt is aligned correctly. If it is tilted slightly it will cause the problem you describe.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Volvord
Year and Model:
Post by Volvord »
The problem is that the lubricating grease, over time, breaks down and becomes very thick and sticky. There is no real way to disassemble the seat belt mechanism to clean and re-lube it. Unfortunately the only solution is to replace the seatbelt.
I have had to replace 3 of my belts
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
JohnR
Post by JohnR »
Yes, I took one of the mechanisms apart and had a 'devil' of a time getting the thing together.
As I presumed, they wear out.
Thanks for the answers.
