Overdrive on an '89 240.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Mrkrinkle
Year and Model:
Post by Mrkrinkle »
Hello
My overdrive seems to be malfunctioning. When I have it on (the indicator light off) it just seems to turn off (light comes on). I could push the overdrive button and sometimes the light would turn off, but it would come back on very quickly. Now the overdrive stays off (light on)...so now it's like a 3-speed I guess. Does anyone know how to fix this?
CarlD
Year and Model:
Post by CarlD »
I fixed the overdrive on my 82 240 and my 88 240.
In one case, I hardwired the switch in the shift knob to always be engaged; full time overdrive activated.
In another situation, the problem was the wire which loops under the tranny and ends at the overdrive solenoid was badly frayed. Fixing the wire resolved the problem.
You may need a replacement relay. It is accessed by removing the glove box. The relays are mounted under the air vent towards the top of the center console.
Had 3 Volvos, sold the 82 240GL, now only 2.
gus
Post by gus »
The overdrive relay located behind the fuse panel fixed the problem on my 89' 740gle.
