In the midst of a steering rack replacement
MarcM
Year and Model: 2005 S60 2.5T AWD
Been thanked: 3 times
Post by MarcM »
Good times. Had a quote of 4.5hrs for $350. Should've done it or called Automeister for a quote. Have the old one out, about to slide the rebuilt unit in. On the tie rod measurements and transfer to rebuilt unit we have the passenger side (right side, in North America) dead on, driver side won't go in the extra 1/8" it needs to go and bottoms out. Luckily we have a toe-in/out rod to get it close until I can get it realigned. That rear motor mount and lower steering coupler is a BEAR. Held me up an hour or more (including coffee/smoke/swearing break). I need to buy a lift, this is ridiculously annoying process on a gravel/crushed stone driveway. ;)
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
$350 is indeed a gold deal when it comes to replace the rack 8)
A few persons mentioned some tie rod brands (inner or outer) not having the original spec length causing the toe not to come withing the adjustment specs. Why was the rear mount hard to get, seized bolt? The lower coupler is horrible but the steering shaft can be disconnected from inside the cabin.
That back massage though :eek:
MarcM
Post by MarcM »
Cardboard on the ground, but the stones find their way though. Sent an email to RackDoctor. Apparently they must be the wrong tie rod ends installed (well, as you notified me... a brand with wrong specs). Probably voiding the warranty but have to go get new ones in the AM and compare to ones on old rack... plus new clamps for boots. That's all I need... more $ spent. LOL.
2005 S60 2.5T AWD
IPD mods:
MarcM
Post by MarcM »
I can't seem to find the thread you mentioned, but I went to find local big box parts stores that would have them in stock (0'Reilly's, AutoZ0ne and Adv@nce). The local state-wide store has them, but are closed on Sundays. Autoz0ne has them... both the long and short one. I saved the large pictures of the Dur@last and the V@luecraft images that supposedly fit, both looked to be different lengths. I went into PSP and mirrored one and scaled to match the stud diameter and positioned them. Flipping back and forth, it's obvious of the ~1/2"+ difference in length.
2005 S60 2.5T AWD
IPD mods:
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
oragex wrote:Why was the rear mount hard to get, seized bolt?
Mine is almost stripped, could not get it moving even with impact wrench :(
MarcM
Post by MarcM »
Rear mount was hard to get to because of sway bar and angle it was at.
SO confused. Just pulled the boot of the rebuilt rack on the suspect side. Correct tie rod as original. Outer tie rods are to the jam nuts and jam nuts are all the way in. No more toe-in available and have 5/8" of toe in (supposed to be pretty much 0". What in the living hell I'm going through is going on?
2005 S60 2.5T AWD
IPD mods:
MarcM
Post by MarcM »
Figured it out. Measured length of rack where the inner tie rods meet rack rod. 33". Same as old one, correct steering rod. Tie rod ends are exactly the right length (yes, correct ones), BUT the old tie rod ends have about 1/4" lead-in where there is no thread. Bright sunlight helps. What we *thought* we saw was that the outer tie rod ends were bottom tapped. After all this measurement and looking with the sun straight into the outer tie rod end... it's NOT bottom tapped. Not going out to drive 20+ miles to look for replacement inners. Chase grinding the threads back and calling this debacle good.... hopefully.
Moral of the story, if you purchase inner tie rod ends you want the threaded end to look like this:
http://www.rockauto.com/en/moreinfo.php ... 56&jsn=354
NOT this:
http://www.rockauto.com/en/moreinfo.php ... 56&jsn=353
2005 S60 2.5T AWD
IPD mods:
MarcM
Post by MarcM »
Yup, that did it. Will be perfect 0 deg toe when we're done. Ended up using Dremel to get threads back 1/4", used angle grinder to take 1/8" off the ends of the new taper and all is good.
2005 S60 2.5T AWD
IPD mods:
oragex
Post by oragex »
Thanks for the info Marc. Not sure, but I think Dorman was of questionable quality any way.
oragex
Post by oragex »
Scary, on mine that bolt plus the rear ones steering rack to subframe look like from the 2nd world war too.
<runs spray some liquid wrench just in case>
