1995 855T Tbelt swap woes
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
Yesterday afternoon, I put in the new tensioner roller and the tensioner. No, I didn't pull the pin! I just couldn't get the Tbelt under the water pump and over the roller. Nothing budged. So I took off the tensioner. The belt went on real easy.
This morning I verified all of the timing marks. Now I cannot get the tensioner into position! The top of the tensioner barrel is touching the bottom of the roller and I cannot pull up the tensioner by hand any more that it already is. I need approximately 3/4" lift to get the tensioner to sit properly.
Stuck!
The belt is routed from the crank, roller, intake cam, exhaust cam, water pump, over the tensioner roller. No slack to the right or between the cams.
What am I doing wrong? This is supposed to be a cake walk. BTW, the belt is the same length as the old one - Conti.
Klaus
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Is the pin still on the tensioner?
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 312 times
Been thanked: 818 times
What about that PITA nub under the crank pulley, are you sure it is not hanging up the belt? Check to see that the timing belt notches are fully engaged down there under the crank pulley.
Klausc
Post by Klausc »
That's IT!!! I initially poo poo'ed your suggestion, and then thought better and verify. Sure enough, that PITA is sucking up 3/4" of the belt.
Now the 'fun' part. Getting that belt on correctly.
Thanks for the bail out!!!
Klaus
Klausc
Post by Klausc »
Erik,
I must have lucked out before or the V70 engine didn't have that nutbuster there. Now I understand why some mechanics remove the harmonic balancer. Sliding the belt in at a 90 degree angle and then turning it to fit is not the best method, but the only one I can think of.
Klaus
Yeah, I do the slide-and-turn method too, I agree not the greatest but it works. It is sometimes difficult to seat the belt in there, good to be on the lookout for the nub.
