1995 855T spring clip woes
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
There has got to be a better way.
I am in the process of replacing my rotted vacuum lines at the BCS. There is a spring clip on the 'red' line which is not visible. I can feel it and the 2 prongs are at about 3pm and the single prong at 6-7pm. Thank you Volvo engineers!
Now, how do I get the darn thing off!!! I don't have a lot of tools. I am trying a regular set of needle nose pliers, but there is no 'feel' and I cannot get a bite on all 3 prongs. I cannot get both hands in there.
And when I get the spring clip off, I know that the vacuum line will be 'welded' to the nipple.
Do these new lines even need a spring clip? The new ones are from IPD and I test fit the blue one on the intake pipe - tight fit!
Klaus
Has thanked: 1850 times
Been thanked: 1712 times
I'm not sure what pipes you are referring to. Are you working on a turbo TCV pipework or what? If you can help narrow down where you are trying to work on the pipework I will try to help you. Some pipes are pressure and some are vacuum. With the vacuum ones a clip is not usually needed but a nice to have to prevent the pipe accidently getting knocked off. On a pressure pipe it is there for a reason! A picture of what/where you are working on in the car would be a great help.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
I remove/destroy the clips and replace them with zip ties.
85 GLH, 367 whp
00 Insight, 72 mpg
Klausc
Post by Klausc »
Scott, I am in the process of replacing the 3 vacuum lines on the boost control solenoid. Two of those lines go to the turbo, red and yellow. The red line is below eyesight and has a spring clamp on it. I am trying to figure out how to get that dumb spring clamp off so I can get the rotten vacuum line off the brass fitting.
I tried with a regular pair of needle nose pliers, to no avail. I can't get any purchase on all 3 tabs of the spring clamp. Once my right hand is down there with the pliers, I am totally blind.
Klaus
Klausc
Post by Klausc »
tryingbe wrote:I remove/destroy the clips and replace them with zip ties.
I wouldn't mind doing that. How do I remove/destroy the spring clip?
Klaus
tryingbe
Has thanked: 1 time
Post by tryingbe »
Pick your weapon...
85 GLH, 367 whp
00 Insight, 72 mpg
Klausc
Post by Klausc »
tryingbe wrote:Pick your weapon...
Very funny. You obviously haven't replaced the 3 vacuum lines for the BCS.
Klaus
kippster41493
Year and Model: 1994 850
Post by kippster41493 »
He's serious, it may entail a bit more work of removing things to fit the tools/ "weapon" in there. I do it a lot, the extra work is worth in in the long run if for what ever reason those lines have to be removed again, all you have to do is clip the zip ties instead of having to do all this extra work every single time.
1994 850 2.3 Turbo :D
1998 V70 GLT 2.5 Turbo :shock: - project now
1995 BMW 530i :)
1998 Eclipse GSR - 3.5" off the ground and headers
Klausc
Post by Klausc »
It's off. A 2 minute job that lasted a total of 3 hours. If the spring clip were centered on the top of the vacuum line (where I put it), real easy. The hard part was using needle nose pliers, they have a flat edge when closed, with other objects in the way, like 1 inch hoses, and unable to see all 3 prongs.
It's break time. The dew point has just passed above 70 and climbing. I will dry out before buttoning everything up and going for a test drive.
Klaus
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Most people have replaced the TCV hoses... and destroying the clips and replacing them either with screw clamps or zip ties is the absolute best way to do it. Unless you want to spend 3 hours on a 2-minute job, that is.
Replacing the bottom vacuum hose from TCV to turbo that you're talking about took me 10 minutes. Airbox out, intake pipe off, good work light, Dremel and a new hose and clamp ready to go.
- S
[Sold] '97 S70 T5
