98 T5 sluggish
- Z06killinsbf
- Year and Model: 1998 V70 T5
I have the majority of the hoses replaced now with silicon. The only ones I haven't done are the bigger ones up under the intake tube by the radiator. Getting the little hose replaced was fun, it's a tad short but it reaches the intake tube just fine.
1998 V70 T5
- Z06killinsbf
Also, the one with the green clip looks impossible to get to with th turbo installed, or else I would have replaced it
1998 V70 T5
- Z06killinsbf
Question: when my PNP went bad and the car went bazerk with all the flashing lights and limp mode, it threw a CEL. I've had the battery out when I repaired the switch and tried pulling codes but yet the CEL remains and is showing no codes on the typical scanner, so that leads to a trans code correct? Should I do a hard reset (touch cables together)?
1998 V70 T5
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
The one that's on your MBC in the picture?Z06killinsbf wrote:Also, the one with the green clip looks impossible to get to with th turbo installed, or else I would have replaced it
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Z06killinsbf
Yes, is it easier than it looks?Sommerfeldt wrote:The one that's on your MBC in the picture?Z06killinsbf wrote:Also, the one with the green clip looks impossible to get to with th turbo installed, or else I would have replaced it
- S
1998 V70 T5
Sommerfeldt
Is that the "original" green one, from TCV to right by the intake on the turbo? If so, that one wasn't a hassle for me, at least. Take out the air box, remove the intake tube, and with a good work light, you'll see it. Cut the old clamp with a dremel if you can't pull it off, and replace with new hose and screw clamp. The hose is probably fused to the nipple there, so slice it and peel off.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Z06killinsbf
Ok, after I invest in some degreaser I'll do that one, it's a bit greasy back there.Sommerfeldt wrote:Is that the "original" green one, from TCV to right by the intake on the turbo? If so, that one wasn't a hassle for me, at least. Take out the air box, remove the intake tube, and with a good work light, you'll see it. Cut the old clamp with a dremel if you can't pull it off, and replace with new hose and screw clamp. The hose is probably fused to the nipple there, so slice it and peel off.
- S
Do you have any input about the trans related CEL?
1998 V70 T5
Sommerfeldt
Your transmission calls up the ECU and asks it nicely to set the CEL, and it calls back until everything's fixed. So you have to clear the DTC from the TCU, which isn't always a walk in the park. It doesn't necessarily go away with a touching battery cables, either.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Has thanked: 1613 times
- Been thanked: 4078 times
Someone nearby with either VIDA or a good AUTEL scanner (500 series on up) can clear that TCM code
They are rare though, Ive never had one on mine.
- Z06killinsbf
So I was able to get someone who could scan it, came back with a P0705. Cleared it 3 times and it came back. Looks like my cleaning of the PNP was unsuccessful, I followed the how to on here.
1998 V70 T5
- 2821 Views
Last post by FLXC90
- 2408 Views
Last post by Matty Moo
- 17 Replies
- 4818 Views
Last post by 850corb
- 12 Replies
- 5503 Views
Last post by alschnertz
- 615 Views
Last post by wlutz
