Dash Cam thought? Hardwiring into power.
- Has thanked: 311 times
- Been thanked: 817 times
Black to black yes but for the hot wire look at your owner's manual, it explains all the different power choices.
- Has thanked: 2200 times
One think to consider too is how you want the cam to work. Some of the cams have a sleep function, and if it senses movement around your car it will turn on. In that case you would want a constant live feed. If you don't have or want that function, then of course you can use a switchable feed. Another option would be the feed to the radio possibly depending on the current draw? The feed to the cigar lighter may be accessible from behind the radio so need to remove anymore than the radio and/or the coin tray section.
speedyt5
- Year and Model: s70 t5, 1999
- Been thanked: 2 times
I could not find the info in the owners manual. Any suggestions on which wire to tap into? It's like defusing a bomb… which wire do I pull? Thanks for the photos!erikv11 wrote:Black to black yes but for the hot wire look at your owner's manual, it explains all the different power choices.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Connector (for accessories) :
Position Connection Max.load
1 Battery + (30)20 A
2 X Supply 0,5 A
3 High beam 1 A
4 1 A
5 1 A
6 Rheostat 0,5 A
7 2 A
8 Earth (31) –
(Note that "x" doesn't mean "2 times whatnot", it means switched.
- S
2 X Supply 0,5 A
3 High beam 1 A
4 1 A
5 1 A
6 Rheostat 0,5 A
7 2 A
8 Earth (31) –
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Not sure where you sourced this info but something is wrong, e.g. there are only 5 positions that are wired not all 8 (look at the photos), and I am pretty sure number 2 is rated to 10A, not just 0.5A ?? Maybe European market cars are different.Sommerfeldt wrote:Connector (for accessories) :
2 X Supply 0,5 A
3 High beam 1 A
4 1 A
5 1 A
6 Rheostat 0,5 A
7 2 A
8 Earth (31) –
(Note that "x" doesn't mean "2 times whatnot", it means switched.)
- S
The ends inside the connector are female, which means you don't even have to cut the wire if you don't want to.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
this is fantastic. I had no idea it was a thing. Worlds of opportunity have just opened in my mind.
Previously I've just tapped into the radio harness. Switched, can tie into the headlight dimmer line if you like, easily reversible or replaced ('cause you don't have to splice into the factory harness).
Sommerfeldt
Hm... I'm not sure either. That's what was in my notes for that thing, from back when I first got the current 850. I was planning on wiring it back up the way it's supposed to be, but thanks for calling attention to it - I may have some wrong info there, apparently.erikv11 wrote:Not sure where you sourced this info but something is wrong, e.g. there are only 5 positions that are wired not all 8 (look at the photos), and I am pretty sure number 2 is rated to 10A, not just 0.5A ?? Maybe European market cars are different.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Sommerfeldt
Here's the one I'm talking about.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Sommerfeldt
... and here's the one in the pictures. Depending on which one's on OP's car, this should be enough to figure out where to plug in the dashcam.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 795 Views
Last post by chris S60LaRosa
- 1349 Views
Last post by mrbrian200
- 2723 Views
Last post by erikv11
- 26 Replies
- 5113 Views
- 780 Views
Last post by SVO LOU
