Front Suspension Torque Specs 98 S70
ktuuri
Year and Model: 98 S70 T5
Post by ktuuri »
Can someone help me with the torque specs on the Front Suspension for my 98 S70
Ball joint on to lower Alu control arm
Lower Alu control arm to frame
Ball joint into spindle
Sway bar links
Main axle nut
Strut
Passenger side axle ubolt that locks axle in place.
I have everything just finished, but instead of arm strong tight, I thought I might do it the right way.
In torque lbs if possible or not. :O)
Thank you!
Ken
Been thanked: 504 times
Post by cn90 »
This should help you.
Don't forget to "preload" the control arm before tightening it.
DIY: 1998 Volvo V70 Front Bilstein TC Strut Tips/Tricks
https://www.matthewsvolvosite.com/forums ... =1&t=28455
ktuuri
Post by ktuuri »
Thank you that does help. A good read as well, with lots of info.
