Loss of boost when hot
I'm starting to think it might be my TCV, not sure why its only affected when hot but I have ordered a Manual Boost Control Valve to have a play with only £12 so a cheap fix if it works, I may even treat it to a proper TCV if it works. I will update in a few days once it arrives and I've fitted it
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
So Volvo uses the TD04 HL turbo which is actually used in a wide range of vehicles. I have seen a lot more turbo issues on Acura's that utilize this design, and it is usually due to bad wastegates, blown air lines, or bad seals. These turbos are fairly robust so i would say your first bet is to use Vida or some sort of scan tool and measure airflow, boost, fuel pressure, etc while doing some runs. Turbos balance a lot of different parameters during operation so any one parameter can throw it out of balance.
One thing i learned from the Acura forum is lazy diagnostics can cost you a lot. The Honda manual calls for turbo replacement far more often then it really should. I've noticed that the volvo forum has been a bit more resistive to parts cannon approaches.
Anyways, get the data and let us know what it says. Lost boost/0 boost is different from low performance, overboosting, etc.
2008 S60 2.5T Auto (Sold)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Yank on the rubber coupler pipe from the turbo to the charged air pipe, they get soft and can easily blow off under pressure, then you let off the gas and it gets sucked back into place and looks completely normal.
- 20 Replies
- 601 Views
Last post by cn90
- 891 Views
Last post by 93Regina
- 38 Replies
- 12250 Views
Last post by mrbrian200
- 67 Replies
- 12098 Views
Last post by clifford06
- 12 Replies
- 1987 Views
Last post by oragex
