I tried to remove drive side knee booster by removing those 3 13mm nuts. However, knee booster was still tight, not lose at all. It did not look like the same as passenger side. How can we remove it ?
Thanks.
1995 855, how to remove driver side knee booster ?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Should have a bolt or 2 going into the center console bracket.
- Has thanked: 316 times
- Been thanked: 531 times
I think there is a fourth nut just above the middle one. I remember having an issue removing the driver's side knee bolster on my V70.
That's right. Take a close look around, I'm pretty sure there was one that was hiding in there near the top.lcc014 wrote:Those 3 nuts are on 2 sides of booster, similar to passenger side. So there is fourth nut in the mid-section of booster ? Let me take a look later ...
Thanks.
- Has thanked: 2199 times
There are only 3 nuts. 2 on the outer side by the door and 1 in the middle. The '4th' nut is not there. The 4th hole is a kind of ratcheted thread in the knee bolster. A hard tug will usually get them to drop. A little bit of brute force is required to get it to clear the 2 sides.
lcc014
- Year and Model: 855, 1995
- Has thanked: 2 times
- Been thanked: 11 times
I looked at the booster again last night, definitely only 3 nuts. Two on the door side and one on the heater core side. I could not feel/find any other nuts in the mid-section of back side. Still it was very very tight to move after 3 nuts were removed. It felt like that it was still hold by more nuts !
Thanks.
Thanks.
Nope, definitely only the 3 nuts holds it in, but there are 4 studs, and they act like a brake on the knee bolster to reduce the chance of it coming off in an accident.
You just have to give it a good hard pull or see if you can get a lever in near the studs to help it on its way.
- 371 Views
- 1968 Views
Last post by sleddriver
- 961 Views
Last post by atikovi
- 14 Replies
- 3347 Views
Last post by kranz
- 9 Replies
- 2587 Views
