Wagon pulls to right During braking then adjusts after brake is let off...
plumsmooth
Year and Model: V70 Wagon 2004
Post by plumsmooth »
Well it is time for me to try and address this issue. Because I don't drive that much, and because I have learned to make the adjustments (2) I have put it off -- but I know I need to check it out...
I even bought a Floor Jack last year and still haven't used it. I only have a very small almost level area of my packed driveway and have been scared to try to jack the vehicle...
Anyway I have narrowed down the problem to either 1. A stuck (open) left caliper piston. 2. A bad control arm bushing? Aren't there three of those?
I'm even more confused because the control arms seem to have a ball joint.
I could swear my mechanic charged me a fortune just to replace ball joints without ever even mentioning the control arm?
Just to recap my Wagon pulls to the right during braking then corrects when the brake peddle pressure is removed...
I'm starting to really see professional mechanics in retrospect as a big rip off...
Anyway I decided to treat myself to an oil change and a tire rotation at my local Vianor.
I decided to start my quest toward front suspension and brake work without standing on a iron bar trying to loosen frozen lug nuts.
They even said they torque their nuts to Vehicle specs meaning I think I'll get 81 ft/lbs meaning I'll be able to get my wheels off to start my training.
I might even ask them to put some anti seize on the threads -- maybe even clean them.
Maybe they could do a quick diagnostic at least tell me if the caliper piston is stuck? Since the wheels will be off anyway...
I don't want to cheat but I'm still only around 50 bucks I think... before the extra requests?
This to me is the way to spend money on mechanics!
P.S> I almost bought an electric impact wrench from Harbor Freight with a coupon this weekend but figured I should at least have the experience of removing lugs by hand once in my life.
I have never had to change a flat tire!
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I doubt a control arm....you would have horrible vibrations while braking if it were that...but you didn't mention that.
difflock54
Year and Model: V40 Nordic 2002
Has thanked: 7 times
Post by difflock54 »
Seized or sticking brake caliper piston on the left side sounds likely from your description.
plumsmooth
Yeah no vibrations at all. However the vehicle does tend to drift a little on the road especially during wind -- but I think that is normal for an old wagon with worn suspension components on Vermont roads?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
When my car was doing this, it was the control arm bushing at the frame of the car.
plumsmooth
Aren't there 3 of those bushings per control arm?
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
Nope, 2 that connect the control arm to the frame.
1996 855 R,
2010 V70 D5,
plumsmooth
Thanks, I just watched the FCP repair video and decided I could easily pull this off if needed.
And I see now two musings one ball joint...
And for 100 bucks for a pair of control arms who would want to if they could.
IS it possible to just replace a ball joint.
I'm almost certain my former mechanic did this and charged me a fortune...
But I might be remembering one of my beater pick up trucks...
Has thanked: 311 times
Been thanked: 817 times
On a 97, the ball joint is not separable from the control arm. It is on a 93 850 and on some other cars, but on your car the mechanic may have said "the front ball joints are shot" and what he meant was, that he was replacing the control arm(s).
Moreover, if the mechanic used any of the widely available, fairly cheap control arms, which he would have charged you a fortune to install, it is very likely that one of them could be ruined already, only 8 or 10 months or whatever later.
The best control arms for your car, the ones that won't break anytime soon, are made by Lemforder and they run about $90 each from RMEuropoean. The Meyle HD ones may be acceptable at closer to $50 each. Control arm swap is a perfect introduction to suspension work: easy access, a few beefy bolts but only a few, guaranteed but minor frustration with rust at the ball joint pinch bolt, get a big hammer in the to pound the old one out and the new one in, be sure to pre-load the arm before tightening the bushing fasteners. Wipe your hands, move to the other side, and do the second one in half the time. Seasoned DIYers can do them in 20 minutes per side. That's after the front end is up on jack stands.
plumsmooth
I think you mean like in the FCP video at 3:54
It amazes me how much money one can save doing-it-yourself!
To think an hour even a two hour job could save 300 dollars.
Between the cost of the parts and the mechanics clock I'm guess a two control arm replacement would cost at least $400...
