'99 V70 Serpentine Belt Change Questions
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Having been emboldened by my recent a/c experience with the '98, I am advised by reliable sources that my '99 V70 needs a serpentine belt change. Since I do not know whether the serpentine belt tensionser and idler have previously been changed, I'm figuring I should probably change them as well. Any tricks/differences between the "98 and '99 that I should be aware of? It looks like they use different style tensionsers. Any acceptable aftermarket brands of tensioners? Thanks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Been thanked: 4065 times
Unless you hear noise or feel funkiness on the tensioner I would leave it be. I've got 180k on my 1999 original
Serp belt is a 10 minute job with a Torx bit ( T45?) on a long extender handle making it easiest.
Draw a picture of the belt path before removal, it's a lot easier than trying memory recall.
Has thanked: 311 times
Been thanked: 817 times
When one of my P80 car's tensioners got noisy this spring, I swapped in another used one.
They fail so rarely that unless you are doing a full engine bay restoration for fun or to sate your OCD tendencies, I would leave it alone.
E Showell
Post by E Showell »
Tensioner is original at 202K miles.
'95 855 auto (sold)
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Mine has over 324,000 and neither has ever been changed. These are different from the small timing belt rollers.
