What Brand of Premium Fuel Do You Use?
- kippster41493
- Year and Model: 1994 850
I use recommended octane mainly at Mobil gas stations, I've noticed any of my euro cars like Mobil better for what ever reason. I did try a tank of the highest octane V-Power at Shell though and it seemed to actually run better. Going to do another trial tank on next fill up (been using Mobil for a few tanks now) and see if I get the same experience and not just a placebo run again.
1994 850 2.3 Turbo
1998 V70 GLT 2.5 Turbo
- project now
1995 BMW 530i
1998 Eclipse GSR - 3.5" off the ground and headers
1995 BMW 530i
- Has thanked: 1611 times
- Been thanked: 4075 times
Never mix Mobil and Shell. People behind you will appreciate it.
- kippster41493
I usually get it pretty empty (about a gallon or so left) out of curiosity why are you not supposed to mix the brands?abscate wrote:Never mix Mobil and Shell. People behind you will appreciate it.
1994 850 2.3 Turbo
- project now
1995 BMW 530i
1995 BMW 530i
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
I've shared this story in the past, but it is relevant again for this post. I used to work for Sam's Club in the Chicago market and the last store I ran had a gas station. We had our annual weights and measures inspection from the State of Illinois and we dispensed a gallon of gas in a container from each pump. I asked the inspector what they do with the gas and he replied they test it for purity and octane level to ensure accuracy to what is posted on the pump. Naturally, I had to ask which gas is the best and he replied without any hesitation Shell is by far the highest quality gas. He told me that the actual octane rating for Shell is typically 2 or 3 points higher than what is posted on the pump. He told me most fuels they test are either spot on or +-1. Not sure if this would apply to the entire country, but should hold true in Illinois.
Eddie G
Eddie G
You get Schmell.kippster41493 wrote:I usually get it pretty empty (about a gallon or so left) out of curiosity why are you not supposed to mix the brands?abscate wrote:Never mix Mobil and Shell. People behind you will appreciate it.
Another satisfied MVS customer.....
(This pun purloined from Click and Clack the Tappet brothers from NPR)
JRL
- Year and Model: Several
- Been thanked: 16 times
Sunoco 93
You should never let a tank get below 1/4 if you can help it
- kippster41493
If you were referring to me as I'm the one that said I get it down to a gallon or so, that's only if I'm switching brands which isn't often at all. Otherwise yes it's always above a quarter tank.JRL wrote:Sunoco 93
1994 850 2.3 Turbo
- project now
1995 BMW 530i
1995 BMW 530i
- kippster41493
What are peoples thoughts on this:
Yesterday I went to a different Mobil station than usual because it was closer to me, normally all the pumps say "up to %10 ethanol" on this pump the mid-grade and low-grade said "10% ethanol" and the premium octane only had "7% ethanol". Is that "guaranteed" 3% difference worth going from mid-grade to premium?
1994 850 2.3 Turbo
- project now
1995 BMW 530i
1995 BMW 530i
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
You should be using premium regardless. As for the ethanol content, I've yet to see any substantial evidence that it's a concern. If it were more readily available I would run e85.
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
Greetings. I use Chevron from my neighborhood station. No Valero, 7-11, Racetrac or "mom and pop gas/ tax prep / hot sandwich " stations. But Shell seems to make performance better in my car and Dodge Ram 1500.
- 23 Replies
- 9854 Views
- 2627 Views
Last post by jimmy57
- 61 Replies
- 14735 Views
Last post by bmdubya1198
- 13 Replies
- 5601 Views
- 20 Replies
- 9821 Views
Last post by JimBee
