2004 Volvo S60 2.5T
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
Tylerb1696
Year and Model: 2004 S60
2004 Volvo S60 2.5T
Post by Tylerb1696 »
Ok so I had my 2004 Volvo S60 overfilled...
Ok so I had my 2004 Volvo S60 overfilled with oil. So I went to drain it and drained out too much but I did not think it was all of it at all because I only drained out 5-6 and it holds 5.8 and it was atleast a quart or more overfilled. So I went to the store to get oil and was on the way back andit got sluggish, oil pressure light came on, the steering wheel locked up, and then the car shut off. So the stick showed no oil and I filled it up to the recommended amount. Then waited atleast 10 mins and tried to restart and it would crank but only for about 15 seconds before it sounds like it loses power and the rpms slowly drop and it shuts off. Please help. There is no check engine light on so I can't use my OBD reader. The oil filter was changed 2000 miles ago just like the oil had. Please help. I would like to fix it myself if I can because I always do. It doesn't make any unnecessary noises. However it does have some black smoke coming from exhaust.. Please help.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
You have a dead engine, time to find a replacement.
85 GLH, 367 whp
00 Insight, 72 mpg
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
When you try to start it, does the engine turn at normal cranking speed? The engine might have partly seized because of lack of lubrication.
