240 speaker installation??? Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
scooby
Post by scooby »
just got the new 4" speakers for my 82 240 turbo. only problem, is i cnt get the grilles off to install the new speakers. i think the grilles may be part of the door panel. i want to know how to take the grilles off and what steps i should take to install the new speakers. thanks!!!
arete
Post by arete »
I have an 81 240 and if similar you might have to take the panels off and undo it from behind. You didn't state but are the screws just turning and not turning out? If so the nut/lockwasher might be turning also.
Guest
Post by Guest »
The grills are part of the door panel. You need to take the entire door panel off to preserve the factory approach to speaker grills.
Work on one side at a time. After you've replaced one speaker - roll
the window down. It doesn't go right? Look at the uninstalled new speaker
compared to the one you've just removed. Are they the same thickness?
Do they sit the same way?
You may have to fabricate some bracket extentions to ensure a tight install and a working window...
scooby
Post by scooby »
the speakers sit too deeply in the wells, and the windows keep hitting them. any ideas on how i can get them to fit. i.e. those bracket extension doohickeys?
arete
Post by arete »
While you are checking that out, make sure your rubber seals around the window to keep the water from draining down behind into the door panel and onto the speakers are still intack and not broken out-
