Alldata maps P1551 to ECM510F, speed sensor signal
If you are using the code reader description of the code, they Are often wrong in my experience
The good news is you now have lots of spare baro sensors !
By the way, the light coming on at 25 kph is the ABS self test. At this speed the ABS burps and tests itself after each start. If the ABS has a problem, that's when the light comes on.
ABS controller revisited Topic is solved
- Been thanked: 4068 times
For a 97 850, which wire is responsible for sending the self test signal?abscate wrote:Alldata maps P1551 to ECM510F, speed sensor signal
ugh smh 850 Turbo fridge
Thats a mattymoo question. Asking me is like asking Forest Gump to explain KAM theory.beigg wrote:For a 97 850, which wire is responsible for sending the self test signal?abscate wrote:Alldata maps P1551 to ECM510F, speed sensor signal
I think the self test is triggered internally when the ABS unit detects fast enough wheel spin to enable reliable speed detection but thats an uneducated guess.
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
There isnt one. It's the module itself is initiating the self-diagnostic, the module is really just a computer.beigg wrote:For a 97 850, which wire is responsible for sending the self test signal?abscate wrote:Alldata maps P1551 to ECM510F, speed sensor signal
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- Has thanked: 316 times
- Been thanked: 531 times
This makes complete sense to me seeing as any scanner program will pull ABS codes through the ABS module, not the ECU. The ABS module does not usually trigger the CEL, from my experience.Matty Moo wrote:There isnt one. It's the module itself is initiating the self-diagnostic, the module is really just a computer.beigg wrote:For a 97 850, which wire is responsible for sending the self test signal?abscate wrote:Alldata maps P1551 to ECM510F, speed sensor signal
Matty Moo
1996-1998, the abs system won't trigger the CEL, 99 and up it will.
2000 s70 GLT
2014 Ram
"1996-1998, the abs system won't trigger the CEL, 99 and up it will"
I suspected my old Autel was unable to read these codes properly which is why i ordered a newer Md802 to read the codes just waiting for it to arrive. So it's possible then my check engine is being caused entirely by the ABS controller problems? Kinda good news.
bummer. thanks for the confirmation!vMatty Moo wrote:There isnt one. It's the module itself is initiating the self-diagnostic, the module is really just a computer.beigg wrote:For a 97 850, which wire is responsible for sending the self test signal?abscate wrote:Alldata maps P1551 to ECM510F, speed sensor signal
Your whole problem could be a wheel sensor or wire which is failing the ABS test
That's definitely possible. Can't you test those with a multimeter?
- 608 Views
Last post by erikv11
- 901 Views
- 9 Replies
- 2330 Views
Last post by Sommerfeldt
- 11 Replies
- 2742 Views
Last post by MrAl
- 14 Replies
- 1795 Views
Last post by MrAl
