The local dealership sold me this gasket (for $10.50 + tx)
https://www.ipdusa.com/products/8532/11 ... ishi-turbo
This is for the Mitsubishi turbo. The Volvo clerk insisted this gasket is right for the '96 850. When I replaced the gasket a couple of years ago I seem to remember it was symmetrical, like the coolant pipe flange gasket on the back of the cylinder head.
Is there a different brand turbo that uses a different gasket that I might need? How can I determine the turbo brand?
96 850 turbo oil return gasket
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
It's the correct one, they redesigned it so that you have something to hold when installing it. I got the exact same one from the dealer. One of my cars I had to remove the banjo bolt to install, the other one had enough clearance
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
mecheng
What about coating it with oil so it doesn't dry out?tryingbe wrote:Clean oil off of both surface, inside the gasket DRY only. DO NOT USE RTV.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Oh, so they redesigned it. Good to know.
I might not have tightened the screws enough last time I changed the gasket. How tight is tight enough? I'm concerned about breaking one of the screws which would probably be impossible to remove, even with the turbo on the work bench.
I was considering using a non-hardening Permatex on the pipe side of the flange, but not on both sides, to reduce the possibility of a leak by 50%. Why is this a bad idea?
Is it even possible to keep dripping oil off the new gasket without leaving the pipe off so that port can drain for a couple of days?
mecheng
You have a leak? It's only a drain hose not sure why it would leak. Replace the rubber seal on the other end of hose. Make bolts tight but they are small so don't kill it. I used a bit of anti seize to make them more serviceable
- 3858 Views
Last post by FlyingVolvo
- 455 Views
Last post by rguzz
- 1643 Views
Last post by rspi
- 705 Views
Last post by Seaway
- 2602 Views
Last post by hubble_xm
