96 850 turbo oil return gasket
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
The local dealership sold me this gasket (for $10.50 + tx)
https://www.ipdusa.com/products/8532/11 ... ishi-turbo
This is for the Mitsubishi turbo. The Volvo clerk insisted this gasket is right for the '96 850. When I replaced the gasket a couple of years ago I seem to remember it was symmetrical, like the coolant pipe flange gasket on the back of the cylinder head.
Is there a different brand turbo that uses a different gasket that I might need? How can I determine the turbo brand?
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
It's the correct one, they redesigned it so that you have something to hold when installing it. I got the exact same one from the dealer. One of my cars I had to remove the banjo bolt to install, the other one had enough clearance
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Clean oil off of both surface, inside the gasket DRY only. DO NOT USE RTV.
85 GLH, 367 whp
00 Insight, 72 mpg
mecheng
Post by mecheng »
tryingbe wrote:Clean oil off of both surface, inside the gasket DRY only. DO NOT USE RTV.
What about coating it with oil so it doesn't dry out?
tryingbe
Has thanked: 1 time
Post by tryingbe »
You do that with seal, NOT gasket.
Install DRY.
NO RTV.
85 GLH, 367 whp
00 Insight, 72 mpg
JimBee
Post by JimBee »
Oh, so they redesigned it. Good to know.
I might not have tightened the screws enough last time I changed the gasket. How tight is tight enough? I'm concerned about breaking one of the screws which would probably be impossible to remove, even with the turbo on the work bench.
I was considering using a non-hardening Permatex on the pipe side of the flange, but not on both sides, to reduce the possibility of a leak by 50%. Why is this a bad idea?
Is it even possible to keep dripping oil off the new gasket without leaving the pipe off so that port can drain for a couple of days?
mecheng
Post by mecheng »
You have a leak? It's only a drain hose not sure why it would leak. Replace the rubber seal on the other end of hose. Make bolts tight but they are small so don't kill it. I used a bit of anti seize to make them more serviceable
