Hello
Should I just go for O rings
I know it's at the Union, and I have a tough time accepting it is the hoses end. I would suspect the rad 1st.
But more wear would come from the O ring?
Any thoughts
98 oil cooling lines leak. O ring or
h20ham
- Year and Model: 1998 xc
And further, we have a Oil smell in the cabin.
So between whatever possibilities from rear main seals, to oil cooler seals. I guess they all get tired.
This beauty has 321,000km
But is in overall good condition.
Just replaced the heater core which I know can smell a bit until it is up to temp. It's been a week now!
And outside of a ok Vlave Stem Seal job and the listed other possibilities
Anything I missed
Anything I missed
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
95 965 T shift controller in progress
05 xc90 rough idle
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
- Has thanked: 2203 times
Have you replaced the oil cooler "o" rings at all? I recommend only using the OE parts and using new clips and a little Vaseline on the new seals to make them go back in without damaging them. Make sure you have cleaned the radiator cooler ports carefully and make sure there are no rust spots to catch and damage the seals.
The cooler lines are not leaking at the swage point where the rubber line starts?
Have you done the PCV system and PTC nipple clean out?
- 1700 Views
Last post by erikv11
- 15 Replies
- 2605 Views
Last post by cn90
- 4178 Views
Last post by GreenMagicMan
- 12 Replies
- 3429 Views
- 1177 Views
Last post by volvodork
