P80 OBD reader Unicorn
Been thanked: 4069 times
Well, Ive reproduced this three times on two cars so Im reporting this strange incident.
I have an AUTEL 802 in the garage for major diagnostics, ABS, SRS resets for the fleet.
Since cars started to disappear for college, each one gets a cheapie AUTEL to read out codes for the driver - she is to log all CELs with a cell phone shot as they happen.
One of my cheap OBDs has a cool feature - when it resets the codes, it leaves all the monitors in READY state!!!
WTF?
Maybe its from VW ??
:D :D :D
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
Which model is it? I'll order one to check it out.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
I've got 5 identical ones, and only one if them does this.
They are Multiscan MS300 models
esl_97_850_T5
Year and Model: 1998 S70 GLT
Has thanked: 18 times
Been thanked: 27 times
Post by esl_97_850_T5 »
Have you isolated the "Readiness monitors always READY" feature to the "unicorn" MS-300 instead of it being a feature of the ECM on the one car it is seen at present. It could be that car's ECM has (illegal) OBDII emission diagnostics Readiness monitors defeating code on it?
In other words, have you tried more than one of the other daughters' MS-300 tools on the car that the unicorn MS-300 is usually used with?
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
Works on both Volvos but not on the VW nor BMW
Strange
dyn blin
Year and Model: 1997 850 Wgn
Post by dyn blin »
For the cost, I will pick one up to be ready to deal with the danged PO442 that seems to pop every other year & 3 weeks before emissions testing...
'97 850 GLT Wagon- Driving to see 300k in the rearview
Well , I bought 5 and only one does this feature , so you have to ask yourself ......
Dyn, remember you can pass emissions with two codes not ready, so passing with the latent evap codes is easy.
If you fill the tank full, evaporated won't trip the CEL until you are at least 3/4 full or less
dyn blin
Post by dyn blin »
I'm glad you posted this, thank you. I thought I recalled that for some mid-late 90's P80's, CARB allowed some leniency on readiness monitors, and I thought I had seen an EPA letter , but haven't been able to find it. I asked my local "SMOG-Only" test facility last year and he hadn't heard of it.
In any case, the full tank reminder is a good one.
dyn blin
Post by dyn blin »
Hmm, not the EPA letter, but it appears this is what's referenced for CA:
https://www.bar.ca.gov/pdf/Smog_Check_O ... _Guide.pdf (page 28)
Interesting.
Just to clarify, in the states , the EPA issued a ruling that :
model years 1999 and earlier can have up to two monitors not ready
Model years 2000 and one can have one monitors not ready.
Generally you can pass your Inspection if your CEL is off with 1 or 2 monitors not ready
It looks like CA is following a slightly different approach per the document above, date Sep 2016
1999 earlier...any one monitor not ready
2000 later...only evap can be not ready
CA readiness rules SEP2016
