Just replaced ECT Sensor... Fan still runs after shutdown Topic is solved
mbaskette
Year and Model: 2000 V70XC
Post by mbaskette »
Working on my 2000 Volvo V70 XC...
This morning I have replaced the ETC Sensor (and thermostat while in there) in an effort to fix the issue of my cooling fan running after shutting down the car. This sensor seemed to be the #1 item on the punch list for this issue. After getting everything back together and topping off the coolant again, I took her out for a good solid run to get everything heated up again. Rolled back into the driveway, parked it, switched it off and removed the key. Fan still running :( .
What is next on the punch list???? Fan relays???
Thanks
Mike
2000 V70XC (53.7k)
2013 XC60 T6 (33k)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
You might want to look into the fan relay. From what I've experienced, if the car has been running a while, the fan will run for a few minutes after shutting off the engine. But that was on a hot summer day. I don't know that it should be running on after turning off the car, especially in cooler weather.
mbaskette
Post by mbaskette »
Thanks... about 54 this morning when I took it out to test the work. Certainly not hot day issue.
2000 V70XC (53.7k)
2013 XC60 T6 (33k)
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
It should do that on 2000 and later cars.Earlier models behave like that only when ect is bad.
2000 and later models owners says that it's normal.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1847 times
Been thanked: 1710 times
My 2000 fan does run after the car is switched off. But again only when I have been driving hard or outside temp is high.
Not sure how long the fan runs for, but maybe if you have a way of measuring the under hood temp, you could monitor the temp with the hood closed and see when the fan switches off and see if the temp is consistent in range when it does. If it is still running all the time, then I'd suspect there is a temp sensor gone rogue or the relay is stuck on.
mbaskette
Post by mbaskette »
Great... well the thermostat and ECT I removed were pretty grungy, so I guess I may have upgrade a functioning system.
2000 V70XC (53.7k)
2013 XC60 T6 (33k)
s10lowrider1994
Year and Model: 2000 v70
Been thanked: 3 times
Post by s10lowrider1994 »
MIne does that, totally normal.
bmdubya1198
Hmm... my cousin's '99 has done that once or twice, but mine has never done that. My dad's old E53 X5 used to run after turning the engine off.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
mbaskette wrote:Working on my 2000 Volvo V70 XC...
Thanks
Mike
It's supposed to keep running if the engine is still hot enough to need it.
Have you plugged in with anything to see realtime temp readings?
How long does it run?
If it's not more than a few minutes, it's probably just doing it's job.
mbaskette
Post by mbaskette »
2000 V70XC (53.7k)
2013 XC60 T6 (33k)
