Check Out my Exhaust Manifold Flex Pipe Repair Please...
plumsmooth
Year and Model: V70 Wagon 2004
Re: Check Out my Exhaust Manifold Flex Pipe Repair Please...
Post by plumsmooth »
I will link it again, this is a much better option:
Exhaust Flex Pipe Leaking
viewtopic.php?t=39723
Pardon me cn90 I didn't mean to brush off your sharing of that link.
I had seen and enjoyed that idea; however it had occurred to me that by the time one removes the Manifold one might as well just replace it rather than all the work involved in splicing in a replacement flex pipe?
plumsmooth
IS there something wrong with this manifold... That I am missing?
I mean I only plan on trying to keep this car another maybe even one year...
Maybe as a back-up vehicle for a few more years after that?
https://www.fcpeuro.com/products/volvo- ... DQodyJ8LCQ
Been thanked: 466 times
Post by cn90 »
plumsmooth,
I am not the author of that facebook link, but from reading it, this is my understanding:
- Leave things in place.
- Use a Sawzall and cut the bad part (flex accordion portion + some of the solid pipe), leaving enough to re-connect.
- Weld the generic flex pipe to both ends and you are done.
Basically they weld both ends with the exhaust manifold in place.
Post by cn90 »
Re PPS vs OBX...I don't know, just go with either generic flex pipe vs OBX.
plumsmooth
Regarding the size of the flex pipe the posts I read mentioned Millimeters (65-67) which I think translated to 2-1/2 inch.
It seems the manifold side flex pipe goes IN then welded; and the tailpipe side it wraps the outside?
Has thanked: 292 times
Been thanked: 765 times
plumsmooth wrote:IS there something wrong with this manifold... That I am missing?
This should be fine for your purposes. But why not get the OBX one for $110? Many people have used that one with success. It comes with gasket(s) but they are worthless, get new ones.
If tomorrow you are still trying to figure out details of how the flex pipe attaches let me know, at that time I can grab a manifold from the garage and take a close look.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
plumsmooth
I am very curious of the details especially since I have wanted a welder recently (to learn) and if one of the Harbor Freight Welders could do this job I would consider doing it my self...
I'm guessing that one chooses a flex pipe diameter that is a compromise between the inside dimensions of the manifold and the outside diameter of the tailpipe to CAT...
Looks like with the manifold cover off one can do at least half of it from above.
With a bad angle on the back through...
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
ZuluR wrote:I tied my whole down pipe in heat insulating wrapping tape that is usually used on the exhaust manifold.
That is a thing you could try perhaps.
Be careful with this if your car leaks any fluids. Header wrap and other fabricky materials can soak up fluids and catch fire when the exhaust gets hot.
I got a 3" stainless flex section welded into my exhaust pipe at a local custom muffler shop for a total of ~$100, materials and labor included, and a 15-minute wait. A smaller-diameter carbon-steel flex pipe plus installation will probably be cheaper. I don't think it's worth spending $30 plus one's own time on hacked-up kinda-sorta solutions when the most-correct solution probably costs $60 and will last as long as the rest of the exhaust.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Can RTV catch on fire? I guess plumsmooth will let us know.
85 GLH, 367 whp
00 Insight, 72 mpg
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
plumsmooth wrote:...however it had occurred to me that by the time one removes the Manifold one might as well just replace it rather than all the work involved in splicing in a replacement flex pipe?
When you remove manifold,time required for welding a new flexi pipe in is about 15min.That 15 minutes includes removal of old flexi pipe and welding in a new one.
Besides flexi pipe,you will need new exhaust manifold gasket for this procedure.
tryingbe wrote:Can RTV catch on fire?...
It shouldn't...it's silicone.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
