2006 xc90 v8 serpentine belt issue
The serpentine belt came off in the last few weeks. ThE Volvo mechanic told Us that the mounts on the engine had broken off and that he would use a smaller belt to bypass these mounts that keep the belt in place. He said in order to replace the mounts it would be a very expensive fix. Has anyone ever heard of this before.
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
What keeps the belt in place is the tensioning force and the ribs (to a certain extent). Can you specify which part exactly broke? (was it the tensioner, one of the idlers, or did the A/C compressor seize)?
I have seen a reverse engineering quick fix like that where a smaller belt is installed, but you have to bypass the A/C compressor.
But that does not sound like an option here in Georgia
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
This happened to our car yesterday. About to order the Timing Cover online ($300). Anyone know what Gaskets and other parts I am going to need for the job?jimmy57 wrote:Yes. One of the idler pulleys seizes up and it breaks the boss it mounts on off the timing chain cover.
New timing chain cover may be needed.
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 28 times
Does anyone know if there is a tutorial for the 2006 XC90 for the V8 engine... Serpentine belt removal and replacement? Have not found one yet.
Thanks
Thanks
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
Crickets???
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
songzunhuang
- Year and Model: 98 V70 T5
- Been thanked: 30 times
I found few links for this, but I haven't done a V8 myself.cuhfs wrote:Crickets???
https://www.matthewsvolvosite.com/forums ... hp?t=61507
http://forums.swedespeed.com/showthread ... -tensioner
Best of luck and let us know how it turns out.
- Song
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
cuhfs
Song Huang, Thanks for the post. Halfway thru serpentine belt job. It is off but can't get the 10MM hex (allen wrench) inside the tensioner to budge. Need to replace that tensioner. It is incredibly tight area and the bolt also is incredibly tight and apepars it will need Hercules strength to open it. Just ordered this tool as it looks like it may do the trick. https://www.amazon.com/gp/product/B007E ... UTF8&psc=1 but have to wait for Monday for arrival.
I will also try to fabricate an allen wrench into a short stubby one with a leverage pipe in the next day or two. So far far more difficult than the other Volvo's I have. At least there's no timing belt on this model
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
Fabricating the stubby allen wrench and leverage pipe was what is needed to remove tensioner. Used the amazon tool for install. Finished job tonight and will test drive tomorrow. very very tight area to work in. As volvo serpentine belts go... this was a tough one. Wonder what the service interval is??? Hope it is a long time before I need to do this again.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
Job done all good. Just drove 100 miles on it. Idler bearings were definitely shot. They felt like sand was in with bearings. Not smooth. Not a horrible job just need a few special tools and patience and know the space is crazy tight where the belt goes so it is tight squeeze to put new belt on.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 20 Replies
- 15304 Views
Last post by Hurtfeelings
- 22 Replies
- 32667 Views
Last post by erikv11
