2005 S80 ABS brake module
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 46 times
Been thanked: 18 times
Post by hu5ker555 »
I'm looking to swap out my ABS brake module. Mine has failed. Does anyone know if S80 and S60 are compatible on the 2005?
I see there is a 2005 S60 arrived at the local pick & pull.
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
In most cases, when the module is replaced it is necessary to reprogram.
hu5ker555
Post by hu5ker555 »
I was able to successfully replace the module in my 2000 S80. Is reprogramming needed on these newer models?
yagger
Post by yagger »
hu5ker555 wrote:Is reprogramming needed on these newer models?
Yes.
hu5ker555
Post by hu5ker555 »
So reprogramming has to be done by the dealer or Volvo specialist?
yagger
Post by yagger »
hu5ker555 wrote:Volvo specialist?
:roll:
hu5ker555
Post by hu5ker555 »
:roll:
So does this mean only the dealer can do this?
yagger
Post by yagger »
No. We know how to do something, too.
doublebug
Year and Model: XC90 2007 D5
Been thanked: 7 times
Post by doublebug »
hu5ker555 wrote:Does anyone know if S80 and S60 are compatible on the 2005?
It will be compatible if:
1 MY is the same
2 ABS type is the same (STC DSTC or TRACS)
3 Power train is the same (4WD or 2WD)
But if it is not compatible and programming is needed I would suggest using BCM from 2006 MY. They are a lot more reliable.
If you have questions about Volvo firmware ask me. I may know an answer :)
Elliot9874
Year and Model: 2004 S80
Post by Elliot9874 »
I have a unused Volvo ABS module for sale let me know if you need it. The part number is 8671456
