00 V70 SE auto slips between shifts? & pinging w/low oct
Andy Segal
Post by Andy Segal »
What could be the problem with low speed slip/hesitation between shifts in an automatic?
Also, is it normal for a 2000 V70 SE with out a turbo to ping on low octane fuels?
Thanks, Andy
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Check the transmission fluid level. Is it orange or brown? Does it smell burnt?
https://www.matthewsvolvosite.com/images ... ne_bay.jpg
What octane fuel are you using?
Also -> Amazon link
Guest
Post by Guest »
I will check the fluid and i was running 89.
I just changed the fuel filter again and am now trying a tank of 93 with a 104 emissions additive. I hope it works.
Are all the 00 V70 non turbos 2.4L?
Thanks again, Andy
Guest
Post by Guest »
Oh, the tranny feels like it is not in gear...not slipage? only under light throttle.
matthew1
Site Admin
Post by matthew1 »
Should not be pinging with good gas and new filter.
Any codes (check engine light)?
I'm pretty sure all 00s were 2.4L.
Also -> Amazon link
Andy Segal
Thanks for all the info.
It is still pinging yesterday with 93 octane...
The oxygen sensor was replaced about 6 months ago but the problem came right back. No longer doing business with Bruces Garage in Norwell, MA!
I am thinking there is something else wrong. Is there an anti-knock sensor?
Also, can not seem to find the auto trans oil dipstick, does the 00 models have one? Is it a auto 4 or 5 speed? the lever has L, 3, 4, D...
Andy
matthew1
Site Admin
Post by matthew1 »
Dipstick location on an 850, should be the same:
Pinging... I don't know. A Guess --> might be the crank position sensor.
Also -> Amazon link
