2005 S60 ABS Pump Motor Replacement Topic is solved
ABS Pump Replacement DIY for 2001-2009 S60
komatiite
- Year and Model: 2004 V70
THANKS! does the car need to be running in order to do this, or just the key in position 2? Also, how long do the valves stay open? Do I need to do this when i bleed each caliper? Or just once after I install new ABS pump?vtl wrote:Goto diagnostic, vehicle communication, select BCM, open activations tab, activate all valves a few times.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Just the key in position II. Valves are triggered for 2-3 seconds. I bled out all trapped air through one caliper, rest of calipers didn't have any air even after ABS modulation.
komatiite
Ok. What is the best method to do this? open bleeder valve and then modulate the ABS through VIDA?vtl wrote:Just the key in position II. Valves are triggered for 2-3 seconds. I bled out all trapped air through one caliper, rest of calipers didn't have any air even after ABS modulation.
vtl
Attach bleeder device, create some pressure (I did 2 BARs), modulate ABS, open valve. Repeat a few times.komatiite wrote:Ok. What is the best method to do this? open bleeder valve and then modulate the ABS through VIDA?
komatiite
Sounds easy enough. Thanks!vtl wrote:Attach bleeder device, create some pressure (I did 2 BARs), modulate ABS, open valve. Repeat a few times.komatiite wrote:Ok. What is the best method to do this? open bleeder valve and then modulate the ABS through VIDA?
- Year and Model: Lots
- Been thanked: 128 times
This is what bled my system on a 2001 XC70 to a T: A hand operated vacuum pump which eventually drew out some flat ale me hearties!!
All the activations in Vida including ABS pump activation didn't help at all.
https://www.matthewsvolvosite.com/forums ... 0&start=80
komatiite
I finally figured out how to add attachments here. top to bottom in the photos is the motor, with the seal, and the pump with the seal still attached to it after i initially removed the motor.
Does anyone know how to get the seal back on the motor? There are a few dozen little nodules in the inside of the upper part of the seal that somehow go into the corresponding holes on the motor. Major PITA to get reinstalled, hence my big leg Emma dilemma.
- IMG_20170106_222046.png (951.06 KiB) Viewed 2069 times
- IMG_20170106_222105.png (1000.81 KiB) Viewed 2069 times
- Been thanked: 4071 times
Is it possible you are overthinking it? That seal isnt a hydraulic seal, just a dust seal. I think I would just position it on the motor and then bolt it back to the pump head
- 774 Views
- 11 Replies
- 7688 Views
Last post by Krons
- 19 Replies
- 3755 Views
Last post by sak54757
- 768 Views
Last post by goldmandan
- 706 Views
