Great information, on both points, Robert. The spare is certainly something to plan for.rspi wrote:But very few P80 cars had the 302mm setup. I've looked at a lot of C70 cars in the junkyard and I have not found a C70 with them in 2 years, probably 20 cars.
I recently had a wheel issue in travel and totally forgot that these brakes will effect my spare options. I had a full size 17" spare this time but wasn't thinking about it.
302mm Caliper Bracket Available at ViVA Performance
- Has thanked: 2854 times
- Been thanked: 1332 times
- Has thanked: 316 times
- Been thanked: 531 times
Yeah... not something I ever thought about! Well, your options are either keep a full size spare that clears the brackets in your car or if you get a flat on the front, just move a rear wheel up front and throw the donut on the back.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Huh, me neither.
I paid like 160 shipped for two brackets, from a Volvo dealer somewhere in California, right after the last crop of brackets ran out. Had some brake work to do and I figured that was the time to do the upgrade. I can't tell any difference in performance - my braking distance is limited by tires, not brake components - but the bigger brakes look cool behind the spokes of my Perfos, so I'm happy with the upgrade. If you're planning brake work, it's absolutely worth the hundo.
Don't forget to upgrade to the 302mm-specific brake lines - these add a not-insignificant amount to the total. But you'll do those and never think about them again, which is worth something.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Sorry I missed this before, but Persus rims will NOT fit with these brackets installed. I went through this last fall, because I had snow tires on Persus for my XC. After upgrading the brakes to the 302mm setup, they did not fit.matthew1 wrote:AK, if nobody replies with an answer, post this question as a New Topic in this forum. It'll get more attention by itself.AKJeeper wrote:I hope this hasn't already been discussed before...but I haven't found any info when I searched. Do the Perseus wheels that came with Platinum Edition 850s clear the 302mm brake setup?
I ended up switching to a set of Perfos which fit the new brakes.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- 12 Replies
- 2755 Views
- 607 Views
- 1024 Views
Last post by Chuck W
- 10 Replies
- 6259 Views
Last post by volvolugnut
- 9 Replies
- 3655 Views
Last post by bmdubya1198
