Spark plug #6 has oil in spark plug well
Hi I have a 2000 s80 2.9 with about 198,000 and just changed out the spark plugs and when I got to #6 it had oil in the spark plug well. The car runs fine with one check engine code for a o2 censor, get about average gas mileage. I'm wondering if this is somthing serious or if it could be just a bad oil cap seal or run off oil because of it the only one having oil and its right in front of the oil fill cap?
ThommyKent
- Year and Model: 91 245 97 850 T5
- Been thanked: 5 times
It`s for sure just oil from someone being sloppy filling oil
ThommyKent
You`re welcome.
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
I would agree, likely sloppy filling. Also, the rubber gasket in the filler cap gets dry and brittle; replacements are cheap (under $1 if you buy carefully,) I just replace them every 3rd oil change. I'd clean it, replace the gasket, and see if the issue comes back.
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
