2006 T5 V70 Coolant Flush - How Much Coolant Can you Drain?
When I drain my coolant via the radiator petcock and engine petcock, I don't seem to get anywhere near the 9.3 qts specified as the capacity. With the car flat, expansion tank cap off, and heaters open I only get about 4 quarts from the radiator and 1/2 quart from the engine drain. This was the same when I first drained the coolant and then again when I drained the distilled water I used to flush with. Can you only drain half of the coolant?
- Been thanked: 4068 times
I drain it by running a live hose while I run coolant out the bottom. Takes about 10 minutes. Make sure you rinse the coolant mix well to,protect pets.
The trick is you only need to load 4-5 liters of coolant to end up at 50-50 mix, so I drain out water, add 100% coolant, then top off with water. On turbo models there is a brass drain cock deep,underneath the engine on the water line but I've never used it.
- 1143 Views
Last post by erikv11
- 18 Replies
- 10982 Views
- 3509 Views
Last post by Krons
- 10 Replies
- 1242 Views
Last post by hausmeister
- 1655 Views
Last post by MoVolvos
