Hi,
I want to remove airbag to adjust steering wheel for volvo xc70 2008 D5.
I could see inside with mirror and torch.
But only I could see flat steel.
I went to Volvo service center but they said I need special tool.
Pls help me to do my job.
Pls help me how to remove airbag.
greenhites
- Year and Model: 2008
greenhites
I have tried many times and finally I could do it.
To do,
- Remove battery terminals.
- Use needle style awl rather then flat or cross screw driver.
That was the reason that I couldnt do it.
- U might not notice that one side of airbag popped up because there will be only one or 2mm pop.
But u will know if its popped or not.
- Turn wheel and do it in same way.
- U will easily find how to unplug airbag cable.
But I couldnt adjust steering wheel because gap between each column is about 2mm which means
there will be about 15degee turn of steering wheel if I move one column.
You will know only when you remove steering wheel and see it.
My limit of English cant explain all.
I still want to know if I can adjust my steering wheel only 3 degrees to right direction.
No worth to replace shock ab sober because my car is too old.
My steering wheel is 4 degree left from centre.
I guess its because one of my shock absber has got problem.
Pls teach me how to adjust if anybody know.
Thanks.
To do,
Thanks.
JRL
- Year and Model: Several
- Been thanked: 16 times
Go to a shop, you need a front end alignment
During the alignment they will set your wheel straight
- 1724 Views
Last post by precopster
- 820 Views
Last post by chintas
