Pls help me how to remove airbag.
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
greenhites
Year and Model: 2008
Post by greenhites »
Hi,
I want to remove airbag to adjust steering wheel for volvo xc70 2008 D5.
I could see inside with mirror and torch.
But only I could see flat steel.
I went to Volvo service center but they said I need special tool.
Pls help me to do my job.
greenhites
I have tried many times and finally I could do it.
To do,
- Remove battery terminals.
- Use needle style awl rather then flat or cross screw driver.
That was the reason that I couldnt do it.
- U might not notice that one side of airbag popped up because there will be only one or 2mm pop.
But u will know if its popped or not.
- Turn wheel and do it in same way.
- U will easily find how to unplug airbag cable.
But I couldnt adjust steering wheel because gap between each column is about 2mm which means
there will be about 15degee turn of steering wheel if I move one column.
You will know only when you remove steering wheel and see it.
My limit of English cant explain all.
I still want to know if I can adjust my steering wheel only 3 degrees to right direction.
No worth to replace shock ab sober because my car is too old.
My steering wheel is 4 degree left from centre.
I guess its because one of my shock absber has got problem.
Pls teach me how to adjust if anybody know.
Thanks.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Go to a shop, you need a front end alignment
During the alignment they will set your wheel straight
