That's a good plan. The feathering throttle routine is another indicator of induction leak.
You really need to remove the parts for inspection, so a pressure test is quicker
00 V70 xc ets light, no cruise, MAF bad, CEL Topic is solved
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
I'd take a look at all the air intake tubing/air charge tubing/vacuum hosing.
Is it surging when you give it throttle?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- ems_kws
- Year and Model: 00 V70 Cross Country
I put some pressure to it and found a hole in the bottom of the intercooler that looks like it was manufactured that way. My parts car has the samr hole but I have not pressured it up yet to see if it leaks.abscate wrote: You probably have a hole or loose clamp in the induction path between the turbo and the throttle body. You've got a lot of symptoms pointing to that.
Here is a pic
[img]
FILENAME FILE COMMENT SIZE STATUS
Hole (600x450).jpg[/img]
I guess I'll pressure test the other before I put it in.
- Intercooler leak
- Hole (600x450).jpg (148.11 KiB) Viewed 1273 times
That hole is okay, it's the weep hole that lets out moisture and small oil seeps. Plug it with gum or your finger when you leak test
- ems_kws
I still have to get to the last air intake line and examine it. I see a few vacuum line that have recently been repaired by the guy I bought it from. I will look into the vacuum lines while digging into the intake connection. Out of daylight today so I'll hit it again after work tomorrow.
- ems_kws
Fixed vacuum lines and took out the intake to verify all the connections. Got it all back together and there is no change. MAF should be here by Thur. Hope that fixes it. Any other things to check out?
Almost forgot. Two injectors have the plastic in the outside of the tip broken. Looks like the previous owner wasn't careful enough when he took it apart. Could this contribute to the issues?
- Injector 1 (600x450).jpg (117.53 KiB) Viewed 1226 times
magna224
- Year and Model: 850 T5's
- Been thanked: 4 times
I popped an intake hose once and it took about a week of driving to get my power back after disconnecting the battery overnight and tightening all my hoses up again. I don't think the plastic bits on the injectors serve much a purpose besides keeping the oring on and taking up space but I might be wrong.
Volvo 855 T5 1995
Volvo 854 T5 1996
Toyota MR2 1987
Volvo 854 T5 1996
Toyota MR2 1987
- ems_kws
https://www.ipdusa.com/products/6581/11 ... low-sensor
I ordered the Bosch MAF from IPD for 70 buck less then a knockoff from the parts house. It fixed the problem and the car runs great. Thanks for the help and advise. I know the car a bit better for having followed the steps to examine the air intake system.
- 3103 Views
Last post by itsmekirby
- 646 Views
Last post by shiloh51933
- 26 Replies
- 6387 Views
Last post by ChadLee
- 24 Replies
- 3747 Views
Last post by smacknab
- 17 Replies
- 6464 Views
Last post by ignatz
