After buying pads last time I realized the c70 with 17" wheels had 2 different caliper disc sizes.
My car has 17" wheels but has the smaller brakes.
I think some of the v70 awd wagons had same brakes but larger, maybe R model.
Who knows what I should order to get mine to the bigger brakes?
I assume change calipers, discs and pads, which v70 r shares same spindles?
04 volvo c70 larger calipers
- Has thanked: 2858 times
- Been thanked: 1332 times
Your keyword here is "302mm brakes". That's what you want. C70s got both 280mm and 302mm. I've never read of a rhyme-or-reason for the C70s getting two sizes. R's got the big brakes.
viewtopic.php?t=46093
302mm brake upgrade on 850
Big brakes on small wheels
more
https://www.matthewsvolvosite.com/searc ... ge?q=302mm
more
tryingbe
- Year and Model: None
- Been thanked: 26 times
Caliper size is the same, brake pads are also the same between 280mm and 302mm.
Caliper bracket is different, so are the size of the brake rotor, and length of the brake hoses.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- 3148 Views
Last post by 93Regina
- 3288 Views
Last post by Rattnalle
- 2006 Views
Last post by motormikeyman
- 9 Replies
- 1327 Views
Last post by V50M66
- 494 Views
Last post by BlackBart
